Configuration Word Of Pic
raedbenz
HI..SOME PIC's THE CONFIGURATION IS LIKE ( __CONFIG _CP_OFF&_WDT_OFF&_PWRTE_ON&_XT_OSC ),
AND OTHERS LIKE THE FOLLOWING EXAMPLE,
LIST P=16F628
#include "P16F628.inc"
__config 0x3F18;----------CONFIGURATION WORD-------------
SO WHAT IS THE DIFFERENCE ?AND WHY DID WE WRITE (_CONFIG 0x3F18)?FROM WHERE DID WE GET THESE VALUES..? IS THERE ANY TABLES EXPLANES THE CONFIHURATION WORDS?
The first method is self-explanatory. Instead, when you write a hexadecimal value, it's difficult to recall what's the function of each bit you're setting or clearing and you should convert the value with the binary notation first.
For example 0x3F18 is 11111100011000. Then check the datasheet of your PIC. The Configuration Word is described there.
LIST P=16F628
For a start please don't use all capital letters, it's considered shouting and rude!.
Both examples give exactly the same result, personally I use the second method because I can't be bothered to do all the typing for the first - which is also obviously far more prone to making a mistake. My programmer software WinPicProg displays the hexadecimal fuse on screen as you select the options you want, so I simply use the value that gives me.
So simple and nice conept,sir, instead of typing the whole lot.
thanks for the idea.
