Comparing output from DS1307
johnl69
Can I directly compare the BCD output from a ds1307 with another register or do I need to convert it to binary first?
i have a program that takes the time from the RTC and compares it with some "alarm" registrys that I have set up;
C:
// ****  Check Blue timer ***********
    if (((hour >= ON_BLUE_hr)&&(minute >= ON_BLUE_min))&&((hour <= OFF_BLUE_hr)&&(minute <= OFF_BLUE_min)))
        BLUE_L = 1;
    else
        BLUE_L = 0;
the ON and OFF registry are set at;
C:
unsigned int ON_BLUE_hr = 0b00001000;
unsigned int ON_BLUE_min = 0b00000000;
unsigned int ON_MAIN_hr = 0b00001001;
unsigned int ON_MAIN_min = 0b00000000;
unsigned int OFF_MAIN_hr = 0b00100000;
unsigned int OFF_MAIN_min = 0b00000000;
unsigned int OFF_BLUE_hr = 0b00100000;
unsigned int OFF_BLUE_min = 0b00110000;
the alarm time display correctly on an lcd but the but the light only turn on when they should.
You might like to have a look here:
http://www.engscope.com/pic-example-codes/real-time-clock-and-calendar/
This uses a data structure to easily compare two date/times.
From what I gather ( i may be wrong) that routine has the alarm triggering at a set time/date which isn't what I'm after I need the alarm to be on between the 2 times incase the power is turned off then the light will go back to what ever state it should be at when the power turn on again.
I compare hours from DS1307 to 'action times' no problems ,, I usually use BCD / hex notation as 0x10 as 10 hours , is the DS set for 12 or 24 hr.
24hr.
A strange thing happened at 20:00 the lights turned on and then 1 minute later they all turned off
I just changed it to
C:
hr = hour & 0b00111111;
   if (((hr >= ON_BLUE_hr)&&(minute >= ON_BLUE_min))&&((hr <= OFF_BLUE_hr)&&(minute <= OFF_BLUE_min)))
        BLUE_L = 1;
   else
        BLUE_L = 0;
Just to make sure there are no extra 1's being read from the extra bits but it's the same.[/code]
My read / write RTC routines always have built in " convert to english" and "convert back to nonsense" routines so its never an issue...
I'll do a BCD to binary conversion on it tomorrow see if it makes a difference.
21:00 when the lights should turn off the blue light came on for 1 minute. it only seem to be working on the set times not between them??
Sorted now, not sure whether it was necisary to convert to binary but it does make it easier to set the times
C:
    binary_hr = BCD2Binary(hr);
    binary_min = BCD2Binary(minute);
    if ((binary_hr >= binary_blue_off_hr)&&(binary_min >= binary_blue_off_min))
        BLUE_L = 0;
    else if ((binary_hr >= binary_blue_on_hr)&&(binary_min >= binary_blue_on_min))
        BLUE_L = 1;
