Voltz
I was trying to make a circuit which alternated outputs, as in when you push the input output 1 becomes high, output 2 becomes low, and when it's pushed again output 2 becomes high output 1 becomes low
The problem is when I push the input momentarily it switches between the two outputs until I release the input and it settles on one, I figure out quickly this was caused by me switching on the input and then the thing switching off the output when the second input on the XOR gate came on (caused by me switching on the input) which then of course means the XOR output becomes high again causing the whole thing to happen again
I tried putting a very small valued capacitor (1pF) in series with the input on the XOR so that after the initial press it would block any signals after that, I don't know if it's the simulator I'm using but this didn't work
So basically I'm asking does anyone know how to block the input so it doesn't oscillate between the two outputs
