Circuit Info Needed: When state goes from 5V to 0 VDC output goes to 5 or 9 VDC?
Satcom
Hello,
I am wanting to build a circuit which when a 5 VDC input goes to zero volts (not necessarily ground) the circuit produces 9 VDC output of up to 100 ma of current from a small "transistor" battery. Does anyone have any ideas? I would like to also be able to adjust the output from 5 to 9 VDC.
This might seem a bit strange, why would I want to produce 5V when 5V goes to zero? I need to use this for when the radio signal into a UHF PIC receiver goes to zero and subsequently the output of pin D1 goes from 5 VDC to zero volts (or close to it). I want to build a solid state circuit which will produce a voltage when that happens to cause an alarm in the form of a voltage output; the full 9 VDC battery voltage of the device. I could do this with a normally open/NO relay too by keeping it energized when the signal was present and then when de-energized close to pass voltage to another device, in this case a piezo buzzer, but I don't want to suffer the continuous current draw of the coil if using a magnetic relay.
Hello,
This might seem a bit strange, why would I want to produce 5V when 5V goes to zero? I need to use this for when the radio signal on a PIC receiver goes to zero and the output D1 pin goes from 5 VDC to zero VDC. I want to alarm when the signal goes away and need to produce some voltage when the 5V disappears.
A LM393 comparator could be configured to detect less then 5V and raise an output to 5v or 9V, you would require a MOSFET or transistor on the comp output to give 100mA.
this is the out put of the simulation
View attachment level converter.pdf
these may help you....
Driver
If I understand you right you want the buzzer to go off when the input goes low.
Here is a transistor implementation.
Thank you very much, those do help me because I'm in Afghanistan and it takes a long time for mail to reach me, but I do have transistors and resistors and can build this quickly.
Regards,
Chris, civilian supporting the USAF
ronv; You need to level shift and invert. The output of your circuit does not apper to invert. Andy
