circuit diagram of a rain sensor and its explanation
kehinde
Please my project reqiures the use of rain sensor to vary the resistance of a resistor in acordance with the intensity of the rain.I need the circuit diagram of the sensor, indicating the correct values of the components required.
In what units is "intensity of rain" measured? What physics is involved in measuring rain intensity? Can you define the requirements for such a sensor?
I'm trying very hard to understand this but I'm drawing a blank.
So your suggestion is to measure volume per unit time in units such as milliliters per minute. OK so we need a way to measure liquid volume, and we need a way to flush the measurement volume so we can repeat the measurement in the next time interval.
I would suggest that it might be easier to measure weight. Since we know the density of water we can compute the volume. Flushing the container then becomes more of a problem.
They're called rain tippers
Ask and you shall find.
Rain is generally measured in depth, so you could say "we had three inches of rain last week".
Obviously all you need to do this is a container, and measure the depth of rain that collects in it. However, this is rather insensitive, so you would usually pour the water into a narrow measuring jug, which gives much greater resolution on the scale - obviously there's a conversion factor involved. Next 'improvement' is to collect the water in a funnel (for the large collecting area), and have the funnel feed directly into the measuring jug.
This is still manual though, and you have to empty the jug as well.
An electronic method is to use a 'see-saw' that works a switch (usually a reed, so there's no mechanical force required). The 'see-saw' accepts water from the funnel on one side, once it gets too heavy the see-saw changes over, the water is tipped out, and the funnel feeds the second side, until that gets too heavy, and so on. This gives a pulse from the reed relay, the speed of which is dependent on the level of rain fall.
You can count the number of pulses for a long term measure of the rainfall, or you can measure the time between them for a fairly real time measure of the amount of rain falling. Obviously it depends on how big the see-saw is, and how much water it requires to tip over.
EDIT: WELL!! - while I was typing someone posted a picture!!
This board is like a box of choclates. You never know what you're going to get!
I was reading through his project notes (so easy to get sidetracked here) on the rain tipper **broken link removed** from an earlier post here.
Some obsevations
Digital inputs are configured for use with dry contact switches. They are not opto-isolated. They are very hard to destroy however and will probably withstand even accidental connection of either terminal to 110VAC without damage.
I have not tried it though. They all have schmitt inputs with RC debounce built in.
PIC inputs are tough but... I feel for those poor clamp diodes.
RS485 line reversal is indicated by oscillating relay 1 at 50hz and it makes a noise you can hear.
For Petes sake WHY...
On the informative side the rain guage is a 0.1 inch per dump type, uses a reed switch and magnet.
That's cool, seems simple to make. A little plastic teeter-totter for rain. And a really nice use for a 1 wire sensor.
Question
What would be the opening diameter at the top?
The larger the funnel opening the more sensitive it is, so you can make it as big as you like - calibrate it by pouring a known amount of water down the funnel (slowly!).
Ahh I thought it was part of a larger equation.
Example if you collected rain with a funnel you would collect scads of it compared to a smaller opening. The tipper in the picture has a tapered opening smaller at the top than the base.
I'm sure you could calculate an equation?, you need to know the accurate level the tipper tips at, and the surface area of the funnel opening - just basic maths!.
No it doesn't, it's not clear from the picture, but the top part is a funnel, with the narrow end at the centre of the 'tipper', the part that goes wider at the bottom is just a housing (it's wider to clear the tipper).
Oh!, I like this board!!
The first picture brought a big grin, as soon as I saw the thumbnail!
If the old adage is right then
you would have to be typing a lot longer to say the same. (I think you did a good job with just a few words, though!)
Darn it Nigel, you're right. Heres a PDF on a complete rain tipper.
I know :D
They built one in a VERY old issue of Practical Electronics (now EPE), apparently the biggest problem is surface tension stopping the water tipping out correctly - but presumably the plastic tipper shown is probably better?, the Pratical Electonics article used a metal tipper soldered together.
BTW, the article fed a mechanical counter, it was probably pre-logic IC's!.
well..what excatly i meant has been explained in the above threads :) .. weigh and trip ...an electro-mechanical device :)
Hello,
Can somebody help me with a schematics and functional description for a rain sensor for automotive. I would like to use a LED and a photodiode for the sensor.
I don't know how to connect this with the wipers or to any drive unit (?!).
Do you have any ideas about a complete schematic including the sensor and the driver for wipers?
Thank you in advance for your support!
When I saw the original post this is the application I thought he was asking about.
Since he asked about having a variable resistance in proportion to rain intensity, I don't see how using a tipper or other water collection device would work. I think he wants something that's "real time" that gives instant feedback based on how hard it's raining - probably for an automatic wiper function.
The ones I've read about seem to rely either on capacitance in an area of the windshield or on reflected light.
