circuit desgn need help. volt bias to sine wave
Mrusten
hi
I have a little project for test equipment but need help to circuit design
I got a sine wave roughly 0-1v varying in the HZ region
this signal need to be the same at the output but added or removed 500mv according to adjustment
and some other features.
I will try to make function blocks here:
Input: sine wave
Adjustment input: pwm 1,4v 2,4khz need to be adjustable sensitivity
Adjustmen on the circuit by pot: end adjustment of the pwm duty cycle 0% (example 0% adjusted to be added +10mv to the sine wave)
between this points its linear so 50% duty cycle is in the middle between those 2 points at all times
Adjustmen on the circuit by pot: end adjustment of the pwm duty cycle 100% (example 100% adjusted to be removed -200mv from the sine wave)
Output: sine wave 0-1v + - 500mv (-500mv and 1,5v
hope it make sense thanks for reading
Welcome,
Need a sketch of the waveforms at each point in the circuit.
Your verbiage is really hard to follow...
Welcome,
hei im totally amatuer to designing circuit so i exspect its wrong, i got basic understanding of electronics so about calculations and so on i dont have a clue.
here is my thinking about how it could be done.
about #3 stage input# im not sure, it may be inpossible but the goal is to be able to adjust where the max point is (max output voltage) and where the minimum is (minimum output voltage)
finally at the #output# the orginale signal can be seen at the - - - - - line and the new output signal is the _______ line,
if the #DC volt out# is 0v offcorse the #output# will be the same as #signal input#
the signal should be only added + or - according to #DC volt out#
the examples is example of max biased signal adjusted in #3 stage input#
(basicly a voltage follower with a volt bias?)
there is 500 mv + or - in the examples but bechause my bad drowing skills it dosent look like so, anyway look at the volt scale at the left.
It seems you expect to have a sinewave which could be shifted in level +/- 500 mV.
Could you answer the following?
Peak to peak value to stay the same?
Frequency to stay the same?
How do you expect to control the level shifting? Manually with a pot or with a signal taken from an existing circuit?
Yes the sinewave have to be the same as input just shifted (phase shift dosent matter)
Yes
Yes
Yes sinewave frequency has to stay the same as the input sinewave (varying 1 hz to 200 hz)
Signal taken from an existing circuit PWM as in the drawing
with manual pot to adjust sinewave shift at 0% PWM
and another pot to adjustsinewave shift at 100% PWM
Level of shifting by PWM as in the drawing but with manual pot adjusted end values (one pot for max dc volt and one pot for min dc volt)
What is going to vary the PWM duty cycle? If it's another pot then the PWM isn't necessary. If it's a microcontroller then the max and min positions could be set in software so you wouldn't need pots for those.
The pwm comes from another circuit where its impossible to change anything
PWM > filter > DC.
DC endpoints adjustable > pot#1 sets DC value for 0% PWM; pot#2 sets DC value for 100% PWM; 50% PWM = ((pot#2DC - pot#1DC)/2)
Input sine + DC value = output.
Correct?
ak
Hola AK,
If the PWM signal is already given, I think that after converting it in a DC signal, a simple pot will ensure the excursion along the whole range.
PWM > filter > DC.
Correct?
ak
correct exept... Input sine + - DC value (+ - 500mv) = output.
about 500mv im happy to get more so that part is not critical
What is the amplitude range of the input Sine?
What is the frequency of the input Sine?
What is the amplitude range of the DC value?
Only if the incoming PWM signal is bipolar about ground, and most aren't. As noted again in post #10, the DC offset can be +/- about GND. First thought (probably a bit weird) is to use the incoming (unipolar above GND) PWM to switch between two voltage sources, both adjustable per post #1. This variable amplitude low voltage PWM waveform is analog filtered, preserving DC accuracy, to give the bipolar DC voltage that is then summed with the input sine. One quad opamp, one voltage reference, one NPN and PNP, a bunch of Rs and Cs. Output sine with be 180 degrees shifted from input sine.
ak
in the hand drawing you can see its 1 volt, but variable so the circuit need to be a voltage follower
as i said before, in the hz region more spesific varying between 1hz and 200hz
its up to the circuit designer.
the pwm signal is 1.4v reference to ground
ak
sounds perfect, the output 180 degree shift dont matter
if you deside to make a circuit diagram please use european standard parts as i got some at home, as lm324
thank you so much
I would be so happy if someone could help to design a circuit like this so i can breadboard it for test and finally make a pcb
Note that for this to work you will need two power supplies, one positive and one negative, like +/-5 V, +/-12 V, etc.
ak
Not that for this to work you will need two power supplies, one positive and one negative, like +/-5 V, +/-12 V, etc.
ak
I understood that from your prevously post #12. Its no problem.
i would prefer a split powersupply
Here is the Bode plot of the EDN circuit compared to a conventional opamp Low Pass Filter. Note that it is almost a 2nd-order Butterworth response with a cutoff frequency of 2388Hz.
In order to properly filter PWM, the frequency of the PWM would have to be at least 10X the filter cutoff freq. Here is the time-domain response of the two filters to 20Khz PWM that suddenly switches from 10% duty-cycle to 90% duty-cycle at 1ms. Note the settling time, the residual 20KHz ripple, and the -2.5V DC offset intrinsic in the EDN circuit.
