hi
I have a little project for test equipment but need help to circuit design
I got a sine wave roughly 0-1v varying in the HZ region
this signal need to be the same at the output but added or removed 500mv according to adjustment
and some other features.
I will try to make function blocks here:
Input: sine wave
Adjustment input: pwm 1,4v 2,4khz need to be adjustable sensitivity
Adjustmen on the circuit by pot: end adjustment of the pwm duty cycle 0% (example 0% adjusted to be added +10mv to the sine wave)
between this points its linear so 50% duty cycle is in the middle between those 2 points at all times
Adjustmen on the circuit by pot: end adjustment of the pwm duty cycle 100% (example 100% adjusted to be removed -200mv from the sine wave)
Output: sine wave 0-1v + - 500mv (-500mv and 1,5v
hope it make sense thanks for reading
Input: sine wave
