That would work also. But a small power transformer, such as 6V filament transformer operated in reverse, would likely be more efficient due to lower resistance windings.A small Transistor Type, Audio transformer would be more Appropriate.
Ok whenever I can see the output of the transformer now with little distortion by means of my oscilloscope, but whenever I place a capacitor at the output the signal disappears?
If you are putting the Cap Across the Output, It will tend to Short out the Signal.
AC can flow through a Cap.
How should I place the cap?
During the first pulse the cap is charged to about 11 volts but it can withstand 30 volts.
Since the second pulse is only about 66 volts I will not benefit from it. Do yu get it?
trying to get FREE ENERGY.
A way to store all the energy is to use the rectified pulses to drive an inductor, not a capacitor. The stored inductor energy can then be used to charge a capacitor, a sort of simple switching boost converter.yes I am trying to store the energy in a capacitor. I place a bridge but the problem is that the first pulse is getting stored and the rest of the pulses are not stored since the cap will have a higher voltage from the first pulse.
You will need a couple of switches to switch between the inductor and capacitor. You ground the output of the inductor with a switch while the inductor is storing the energy. The you open that switch and close another to connect the inductor output to the capacitor which converts the inductive current into a voltage on the capacitor.
One switch from the inductor output to ground and one from the inductor output to the capacitor.OK this is fine but what should the switches be and please don't forget that this is a self powered circuit.
Self powered is a problem. Perhaps a bootstrap circuit powered by a separate diode and capacitor from the input. This would only capture the peak signal, of course, but may be enough to power the circuit initially and start the process. After that it could be powered from the normal inductor-capacitor output.
-------D1----------L1-----------
D2 C1
gnd gnd
Nothing energy from the second pulse will be stored, unless it's voltage is greater than the voltage already at the capacitor.
