checking sequence using IF statement
ycho
Hi
I am trying to check the sequence using if statement.
first : IR1 and IR3 goes low and IR2 and IR4 stay high
check by while loop, if it is true then go to next if statement.
second : IR1 ,IR2,IR3 and IR4 all goes low.
lastly :IR1 and IR3 goes high and IR2 and IR4 stay low.
if fulfill above requirement, LCD will increment by one.
I had wrote the program but the program doesn't work.
can someone figure out the problem for me.
below is my code
#include <16f877a.h>
#use delay(clock=20000000)
#fuses hs,noprotect,nowdt,nolvp
#define use_portb_lcd TRUE
#include <lcd.c>
#define IR1 Pin_A0
#define IR2 Pin_A1
#define IR3 Pin_A3
#define IR4 Pin_A4
void main()
   int people_in = 0, people_out = 0;
   set_tris_a(0b00001111);
   lcd_init();
   lcd_putc("\fAutomatic Room");
   lcd_putc("\nLight Controller");
   delay_ms(5000);
   lcd_putc("\f");
display_1st :
   lcd_gotoxy(1,1);
   lcd_putc("People in  =  \n");
   lcd_putc("People out =  \n");
   lcd_gotoxy(14,1);
   printf(lcd_putc,"%3u",people_in);
 do{
if (input(IR1)==0 && input(IR3) ==0 && input(IR2)==1 && input(IR4)==1)
while((input(IR1) && input(IR3)) ^ (input(IR2) && input(IR4)));         // (0 AND 0) = 0  (1 AND 1) = 1      0 XOR 1 = 1= TRUE
if (input(IR1)==0 && input(IR3) ==0 && input(IR2)==0 && input(IR4)==0)
while((!input(IR1) && !input(IR3)) && (!input(IR2) && !input(IR4)));    // 1 AND 1 AND 1 AND 1 = 1 = TRUE
if (input(IR1)==1 && input(IR3) ==1 && input(IR2)==0 && input(IR4)==0)
               people_in += 1;
               lcd_gotoxy(14,1);
   }while(1);
its more like:
if ((input(IR1)==0) && (input(IR3) ==0) && (input(IR2)==1) && (input(IR4)==1))
You need each check in its own Parenthesis ()
This looks ambiguous as you're looking for ALL inputs on and not what your comments imply.
Cheers Ian
The code is very poor, hard to understand and slow to execute.
Why not try detecting all bits at once? That's faster and much neater.
Something like this;
inputs = (PORTA & 0b00001111);  // keep only 4 bits
if(inputs == 0b00000011) blah;
if(inputs == 0b00001111) blah;
