Changing Fosc on the go.
MrNobody
Hey guys..
Below are some of the code to read ADC on both AN0 and AN1 at 2Hz using PIC12F615.
The default FOSC is 4 MHz using internal oscillator.
There is a switch connect to GP2 and when the switch is pressed, GP2 -> HIGH.
What I'm trying to do is when the switch is pressed, I want to PIC to run at FOSC = 8MHz. When the switch is released, I want the PIC to run back at Fosc = 4MHz. As in, the PIC will just change its FOSC on the go.. Below is the rough code. As you can see, when GP2 -> HIGH, ANSEL and IOSCFS will change accordingly so that the PIC will sample at 4Hz instead of 2Hz.
Hmm.. will it work..? Is there any thing I missed..?
How long will it need for the internal oscillator to stabilize to its new Fosc..?
#include <pic.h>
/***** CONFIGURATION *****/
// Config: 4MHz int clock, no watchdog, ext reset disbled, no code protect
__CONFIG(INTIO & WDTDIS & PWRTEN & MCLRDIS & UNPROTECT & BORDIS);
void adc_read(unsigned char channel)
	ADON = 1;
	ADCON0 = (channel << 2) + 0b00000001;	//
	GODONE = 1;
	while(GODONE)
		continue;	// wait for conversion complete
	ADON = 0;
void interrupt isr(void)
	static int cntTMR0 = 0;
	TMR0 += 256 - 250 + 3;
	T0IF = 0;
	if (++cntTMR0 == 2000) 	// loop 2000 times to make 0.5s (for 4 MHz)
		cntTMR0 = 0;	// interrupt occur every 250us. 2000 * 250us = 0.5s
		ReadADC = 1;
void main()
    	// Initialisation
    	// ports
    	TRISIO = 0b00011111;
  	// Timer0
  	OPTION = (OPTION & 0xC0) + 0x08;
                                    //  Bit 3 - Prescaler assigned to WDT
                                    //  Bit 2:0 - WDT Rate = 1:1
  	// Interrupt
  	T0IE = 1;	// Enable TMR0 interrupt
  	ei();		// Enable global interrupt
	// configure ADC:
    	CMCON0 = 7;                 //  Turn off Comparators
	ANSEL = 0b00010011;	    //  Set GP0 and GP1 as analog
				    // 	Select the Clock as Fosc/8
    	ADCON0 = 0b00000000;        //  Turn on the ADC
        	                    //  Bit 7 - Left Justified Sample
                                    //  Bit 6 - Use VSS
                                    //  Bit 4:2 - Channel 0
                                    //  Bit 1 - Do not Start
                                    //  Bit 0 - Turn on ADC
	while(1)
	    	if (ReadADC == 1)
			ReadADC = 0;
			adc_read(0);
			ADC1 = ADRESH;
		    	adc_read(1);
		    	ADC2 = ADRESH;
		if (GP2 == 1)
			// 8MHz
			ANSEL = (ANSEL & 0x0F) + 0x50; // Change TAD for 8 MHz
			IOSCFS = 1;  //Internal Oscillator Frequency Select bit
		else
			// 4MHz
			ANSEL = (ANSEL & 0x0F) + 0x10 // Change TAD for 4 MHz
			IOSCFS = 0;  //Internal Oscillator Frequency Select bit
You can't write to the config register in code and so this will not work.
