Arvorsteve
Hi
I am trying to source a circuit diagram for this Chinese inverter without much luck. I established that two of the IGBT's had failed as had a surface mount 10 ohm resistor and a 2 watt 1kohm resistor, all in the same output stage area of the board. Having changed all observable noticeably failed components the 1k 2 watt resistor started smoking and I now have a low resistance across one of the IGBT's suggesting that whatever has failed previously took out the IGBT again!
Any help or links to a possible circuit diagram source would be appreciated.
Steve
Steve
