Hi guys,
I have compiled a program in HITECH C which uses a software bit banged serial routine on a 16F887. All works fine, same board, same level shifts etc, but this time I created a simple program using CCS C V4.105 and the serial message is coming out with parity errors and incorrect data. Any help appreciated.
4MHZ internal clock btw.
Code below.
main.c
main.h
Code below.
main.c
void main()
setup_oscillator(OSC_4MHZ);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_ccp1(CCP_OFF);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
enable_interrupts(GLOBAL);
while(1)
printf("1234");
delay_ms(1000);
#include <16F887.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES INTRC_IO
#FUSES NOPUT //No Power Up Timer
#FUSES NOPROTECT //Code not protected from reading
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD //No EE protection
#FUSES NOWRT //Program memory not write protected
#FUSES RESERVED //Used to set the reserved FUSE bits
#use delay(clock=4000000)
#use rs232(baud=9600,xmit=PIN_A0,rcv=PIN_A1)
