ccp1if problem
kvrajasekar
I am trying to use ccp in compare mode,i tried to set the out high on match,I got the output on timer1 and ccp register match,but i didnt get the cc1pif interrupt.and also it gets increment every instruction...
my code is follows,
list p=16f72 ;PIC16f72 is the target processor
INCLUDE "P16f72.INC"
__CONFIG _PWRTE_ON & _XT_OSC & _WDT_OFF ; configuration switches
org 0x00
goto main
org 0x04
btfsc PIR1,CCP1IF
goto pwm_loop
main bsf STATUS, RP0 ;Bank1
movlw b'00101111' ;Defining input and output pins
movwf TRISA ;Writing to TRISA register
movlw b'00001111' ;Defining input and output pins
movwf TRISB ;Writing to TRISB register 1-input,0-output
movlw b'00000000'
movwf TRISC
movlw 0x00
movwf ADCON1
bcf STATUS, RP0 ;Bank0
clrf PORTA ;potra,portb initially set to low
clrf PORTB
clrf PORTC
clrf CCP1CON
bsf INTCON,PEIE
clrf PIR1
bsf PIE1,CCP1IE
bsf INTCON,GIE ;Enbles interrupt.
bcf T1CON,TMR1ON
movlw d'8'
movwf CCP1CON
movlw 20
movwf CCPR1L
movlw 30
movwf CCPR1H
clrf TMR1H
clrf TMR1L
bsf T1CON,TMR1ON
wait goto wait //waiting for match
pwm_loop
end
please correct me if any wrong coding...
Regards,
Raja.
Your code is not going to work for a couple of reasons,
PIE1 is in bank 1 - not bank 0.
Your interrupt is going to jump to the end of the code and execute random memory.
If you want to wait for the match then poll the CCP1IF to see when it completes.
		__config _PWRTE_ON&_XT_OSC & _WDT_OFF  ; configuration switches
		org	0x00
main		bsf	STATUS,RP0	;Bank1
		movlw	b'00000000'
		movwf	TRISC
		movlw	0x00
		movwf	ADCON1
		bcf	STATUS,RP0	;Bank0
		clrf	PORTB
		clrf	PORTC
		clrf	CCP1CON
;removed interrupt bits
		bcf	T1CON,TMR1ON
		movlw	d'8'
		movwf	CCP1CON
		movlw	20
		movwf	CCPR1L
		movlw	30
		movwf	CCPR1H
		clrf	TMR1H
		clrf	TMR1L
		bsf	T1CON,TMR1ON
wait		btfss	PIR1,CCP1IF	;wait until TMR1=CCPR1
		goto	wait
;will get to here when match occurs
		bcf	PIR1,CCP1IF	;clear the flag
Hang		goto	Hang
		end
