CCFL inverter
2PAC Mafia
Hi guys,
I´m trying to find a replacement backlight inverter to repair a customized on board 2 serial transformer inverter which is damaged at customized transformers. I took measurements from original working device making a 10 x 1Mohm resistor in serial line between common and hot to be able to measure, parallel to working CCFL. I measured 89Vrms and 36KHz signal on a resistor. I measured 180mA consumption difference at main 24V input with and without backlight.
I have tried to get the correct bright on the CCFL using 4 different backlight inverters but always the result is very low bright. The last one was 900V 35Khz (BXA-12529). The feeling is that it is not enough to trigger the CCFL.
Any advice to solve this?
