Can't find connector small enough
Flyback
Hello,
Hello, we need a wire to board connector, 2 way. Size less than 13mm x 8mm (length x width), and height less than 10mm
We need the connector (>0.5A) and rated to 400V at least. Though in nominal use it will have 75V between terminals.
This is the connector (Wago) we currently use and its too big......
Wago 2060-402/998-404 connector:
https://www.farnell.com/datasheets/...MIuJKv2sXw1wIVRrcbCh19bQMeEAAYASAAEgKaW_D_BwE
We simply cannot find anything, we have searched Wago, Pheonix, Molex, JST, etc, but nothing.
Any ideas appreciated?
Does it have to be push-button type? Screw type would widen the field of search.
Are you just allowed to use a 3 position 0.100" headers and crimp housings (with or without a latch) where the center position is not populated?
The voltage rating says 250VACrms /176VDC but below it says 500V insulation resistance between adjacent pins. I'm not entirely sure what the difference is between the two ratings.
https://www.molex.com/pdm_docs/ps/PS-7879-001.pdf
