Can't find 60Hz Oscilator!
Lac
I'm about building a digital clock, and I have read that I need a 60Hz Oscilator, but I cant seem to find oscilators that low! Every oscilator is rated in MHz not Hz. I only find 60MHz , do the producer mean that 60Hz and 60MHz are the same? Can I use a 60MHz oscilator instead?
Thanks!
Lac.
hmm.. but what if I buy a clockcrystal (32KHz) and then buy 5 decade counters and then devide the frequency down to 1Hz? (32000/10/10/10/4/8=1Hz) weird idea :D , but will it work?
Thanks!
Lac.
What You need exactly 60Hz or 1Hz? Some alarm clock chips need 60Hz clk freq. 60 MHz (or 6 or 3MHz) quartz and decade counters is a good choice. 32768kHz Xtals most of case cheap, but low quality.
Serious? Is that the way to do it? buying 5 decade counters and devide it down? But I have limited space for the chips (ca. 2x2") aren't there any other way to do it?
These chips wil drive 4 LED-Displays that contain 4-6 elemts each. So they will drive ca. 16 displays ( four digital clocks that run simously.)
one hz is a possible output but not 60 hz.
why?
What about using a 555timer IC? but I can't seem to figure out wich combination of resistors and capacitor to use to get 1Hz output. help?
Cheers!
Lac.
Or use a MM5369 IC as the 60 Hz source, these are very accurate and use a commonly available 3.58 Mhz TV colorburst crystal.
For a stable 60 hz use this circuit:
It would work, but wouldn't be very accurate - a free running oscillator isn't much use for a clock! (think + or - one hour per week!).
if you live in the states, you can get the 60Hz from the outlet. edison doesnt guarantee 120V, but they do guarantee 60Hz. with a bit of circuitry, you can get a 60Hz squarewave. if you live in an area that supplies 50Hz, then perhaps a 555 timer with a trim pot would work for you. some companies used to have 60hz time-base generator ic's. may have discontinued them. perhaps you can find a place that specializes in hard to find ic's.
nope, I live in Norway, here we have 230v 50~60Hz , not accurate. But thanks A LOT for all the help i have recived, I have learnt incredibly much from it.
Cheers!
Lac.
