can anyone help ?
slifer88
i need to interface matlab with the parallel port..in order to send 1's and 0's on the parallel port data pins..can anyone help in that matlab code plzzzzz !!! :( :(
You can use a C function to access the ports through e.g. io.dll
The C program should be compiled using the matlab compiler so that you can use the C functions you just wrote.
I don't have matlab installed properly at the moment, but I've compiled programs for matlab before - it was very easy.
To compile (or just google for other instructions):
Plz i have problem when compile the file and tell me that in the Output:
Debug build of project `D:\TEST\TEST.mcp' started.
Language tool versions: mpasmwin.exe v5.34, mplink.exe v4.34, mcc18.exe v3.34
Preprocessor symbol `__DEBUG' is defined.
Sun Dec 27 19:52:45 2009
Clean: Deleting intermediary and output files.
Clean: Deleted file "D:\TEST\TEST.mcs".
Clean: Done.
Build aborted. The project contains no source files.
Debug build of project `D:\TEST\TEST.mcp' failed.
BUILD FAILED
