Im making an electromagnet that will be more or less permanently turned on so I need to avoid heating problems. I have studied this a bit and came to the conclusion that:
the lower the gauge (AWG) (the thicker the wire) and the more turns around the core => the greater current it can handle and the lower the heat.
with this in mind I would have taken something like 500 turns around a 10 mm diameter screw, with pretty thick copperwire awg 20 (0.5 mm) or something similliar would be okey?
What do you say? Is there a way of calculating these heatingproblems before I decide the dimension and number of turns of my copperwire?
