calc Tr of aluminum object?
justDIY
Active Member
Is there a way to calculate the thermal resistance of an aluminum object?
I have these cool bowls made from cast aluminum. they're about 1/8" thick material, and about 4" square and 1.5" deep.
i'd like to just get a rough ballpark to see if further testing is feasable (which may otherwise deface the bowl) or if it's a non starter
here's the object in question
https://projects.dimension-x.net/pictures/albowl/topdown.jpg
It is possible to estimate the thermal performance - estimate suggests a level of inaccuracy. It's also possible to more accurately calculate the thermal performance. The "estimate" takes some work - the calculation quite a bit more and/or some fairly expensive software.
It might be simpler to experiment to see how it performs. How much effort should be applied is likely determined by your specific needs.
