C30 Craziness... Wots going on here?
krazy
Hey everybody,
I'm trying to code my Microchip dsPIC33FJ with some fairly simple code. I don't know why it's not working though. :confused:
Here is my code:
	void initS2P(void)
		TRISA = 0x00;  // init all of A register as outputs
		LATA = 0x00;   // clear that bad boy out, just to be sure
	void clockSR()
		PORTAbits.RA2 = 1;
		PORTAbits.RA2 = 0;
	void updateLEDArray(int shift[8])
		int bitNum;
		for(bitNum = 7; bitNum == 0; bitNum--)
			PORTAbits.RA3 = shift[bitNum]; // put bit on SER
			clockSR();                     // clock SRCLK
		PORTAbits.RA4 = 1;  // clock REGCLK
		PORTAbits.RA4 = 0;
	initS2P();
	int bitArray[8];
	bitArray[0] = 0;
	bitArray[1] = 1;
	bitArray[2] = 0;
	bitArray[3] = 1;
	bitArray[4] = 0;
	bitArray[5] = 1;
	bitArray[6] = 0;
	bitArray[7] = 0;
	updateLEDArray(bitArray);
But, for some reason, none of it is working? I can manually switch the pins. Commands like:
PORTAbits.RA2 = 0;
PORTAbits.RA2 = 1;
would leave RA2 high.
Additionally, I can copy and paste those lines hundreds of times and it works.
Oddly, though, when I simplify it into functions, it stops working.
For some reason, when I de-abstract the code and make it one long main, it then stops working again.
Any ideas?
The code in this for loop will never be executed.
Change BitNum to signed and the above to,
    for(bitNum = 7; bitNum > 0; bitNum--)
try that:
But it only works if bitNum is signed.
An alternative for unsigned is,
for(bitNum = 7; bitNum < 8; bitNum--)
Not obvious why but it should work.
Whoops, that code should have been,
    for(bitNum = 7; bitNum [COLOR="Red"]>[/COLOR]= 0; bitNum--)
in which case if it's not signed then it can never be less than zero.
I think arhi has it figured. Check the assembler listing for a working scenario and a non-working one. I'll bet there are extra instructions in the working code that provide a bit of a delay between pin toggles. Using LATAbits instead of PORTAbits as mentioned by arhi is the way to go anyway because it totally avoids the classic read-modify-write bug.
