C18 compiler : include header files
SneaKSz
Hello ,
I'm having problems with including header files with C18 compiler in MPLAB. I want to include these files into a project :
#include "lcd.h"
#include "delay.h"
I also included these header files into the project also the linker file for my PIC.
This is the main program :
#include <p18f14k50.h>
//#include <htc.h>
//#include <pic18f1xk50.h>
#include "lcd.h"
#include "delay.h"
	#pragma config   CPUDIV = NOCLKDIV
	#pragma config    USBDIV = OFF
	#pragma config    FOSC = HS
	#pragma config    PLLEN = OFF
	#pragma config  FCMEN = OFF
	#pragma config   IESO = OFF
	#pragma config   PWRTEN = ON
	#pragma config    BOREN = ON
	#pragma config    BORV = 30
	#pragma config   WDTEN = OFF
	#pragma config    WDTPS = 1
	#pragma config   MCLRE = ON
	#pragma config    HFOFST = ON
	#pragma config    STVREN = ON
	#pragma config    LVP = OFF
	#pragma config   BBSIZ = OFF
	#pragma config    XINST = OFF
	#pragma config   CP0 = ON
	#pragma config    CPB = ON
	#pragma config    CPD = ON
	#pragma config    WRT1= ON
	#pragma config   WRTB = ON
	#pragma config   WRTC = ON
	#pragma config    WRTD = ON
	#pragma config    EBTRB = ON
  #define LCD_PORT	LATC		//	;set constant LEDPORT = 'PORTB'
  #define LCD_TRIS	TRISC		//	;set constant for TRIS register
 //volatile bit LCD_RS @ (unsigned)&LATC*8+4;
			//;LCD handshake lines
  #define LCD_RS LATC4
  #define LCD_RW LATC5
  #define LCD_E	 LATC6
	unsigned int 	templcd	 =0 ;
	unsigned int	ADCH;	//temp store for 4 bit mode
	unsigned int	ADCL;
	unsigned char   w;
	unsigned char   conv;
void initLCD( );
void ADC_Init();
void ADC_Go();
//void Pulse_e();
//void LCD_Char(unsigned char);
//void LCD_Cmd(unsigned char);
//void Delay (unsigned int );
void main(void)
unsigned long ad_val;
float angle;
	unsigned int	AH=3; //0000 0011 = 384
	unsigned int	AL=100; //1100100
// both = 484
	ad_val = AH;
	ad_val = ad_val << 8 | AL;
	angle = (float) ad_val * 5.0 / 1024.0;
// 2.3632?
// testings
	OSCCON =62; //set internal clock to 4MHz
  	LCD_TRIS = 0;  //	set PortC all outputs
  	LCD_PORT = 0;		//LCD_TRIS
	Delay ( 100);
	LATB=0x00;
	templcd = 0;
	ADCON1 = 0b01111111; // set as digital I/O
	Delay ( 255);
	void initLCD(); // [COLOR="Red"][SIZE="3"]ERROR HERE[/SIZE][/COLOR]
	void ADC_Init();
	while (1)
	void ADC_Go(); // ADC values will still be displayed on the LCDHI-TECH C
	Delay(255);
	LCD_Cmd(1); // clear screen
	ad_val = ADRESH;
	ad_val = ad_val << 8 | ADRESL;
//LCD_Char(0x31);
//LCD_Char(0x32);
void ADC_Init()
		ADCON2 = 0b10101110 ;//right justify, Frc/64 , 12Tad
		ADCON1=0b00000000 ;//ADC ref = Vdd,Vss boven- en onderste venster
		LATB4=1;//Set RB4 to analog (ANS10)
		ADCON0 = 0b00101001 ;//AN10, ADC on
void ADC_Go()
	GODONE =1 ;//Start conversion
//ADCPoll:
	while(GODONE ==1); //Is conversion done?
	//	; Result is complete - store 2 MSbits in
	//	; RESULTHI and 8 LSbits in RESULTLO
		ADCH = ADRESH;
		ADCL= ADRESL;
the compiler gives an error when I try to execute this :
"... C18_LCD_ADC\ADCLCD.C:85:Error: syntax error " . This refers to " void initLCD();" wich is a function of lcd.h.
LCD.h code
#ifndef __LCD_H
#define __LCD_H
void initLCD();
void LCD_Cmd (unsigned char w );
void Pulse_e();
void LCD_Char (unsigned char val);
#endif
LCD.C code
#ifndef __LCD_C
#define __LCD_C
#include   "C18_LCD_ADC.c"
#include   "lcd.h"
#include   "delay.h"
  #define LCD_E	 LATC6
void initLCD()
//INIT FROM THE PDF
	//	    LCD_PORTbits.LCD_RS = 1;
	//		BCF     LCD_PORT,LCD_RS ; make the LCD ready to take ORDERS
	  	    Delay (254);
			LCD_Cmd(0x33);	//Set 8 bit mode
			Delay(5);
			LCD_Cmd(0x32);	//Set 4 bit mode
			Delay(5);
			LCD_Cmd(0x2C);//function set 2 lines; 5*11
			Delay(5);
			LCD_Cmd(0x08);//display off
			Delay(5);
			LCD_Cmd(0x01);//display clear
			Delay(5);
			LCD_Cmd(0x06);//		entry mode set increment , no shift
			Delay(5);
			LCD_Cmd(0x0F); //disp ON
			Delay(5);
		//	call	LCD_Clr			;clear display
void LCD_Cmd (unsigned char w){
	templcd=w;
	w= (templcd >> 4) | (templcd << 4);	;//send upper nibble
	w=w & 0x0f ;//clear upper 4 bits of W
	LCD_PORT=w;
	LCD_RS=0;//RS line to 0
	Pulse_e();				;//Pulse the E line high
	w=templcd	;//send lower nibble
	w=w&0x0f				;//clear upper 4 bits of W
	LCD_PORT=w;
	LCD_RS=0 ;//RS line to 0
	Delay(5);
void Pulse_e()
	LCD_E=1;
	Delay(5);
	LCD_E=0;
	Delay(5);
void LCD_Char ( unsigned char val)
	templcd = val;
	val=(templcd >> 4) | (templcd << 4);
	val=val & 0x0f ;//clear upper 4 bits of W
	LCD_PORT=val;
	LCD_RS=1;//RS line to 1
	Delay(5);
	Pulse_e();
// second part
	val=templcd	;//send lower nibble
	val=val&0x0f				;//clear upper 4 bits of W
	LCD_PORT=val;
	LCD_RS=1 ;//RS line to 1
	Delay(5);
	Pulse_e();
	Delay(5);
#endif
I think I"m including these files in a correct way , but I can't see the problem.
I"ve looked all over the internet to find examples of people who also included self made header files ( no library ) , but it's hard to find.
Someone can help me with this small problem , how to include header files?
Thanks in advance !!!
ill add you can have the files in a separate folder and include them like:
#include "\newfolder\lcd.h"
or
#include "newfolder\lcd.h"
Not sure if first \ is needed
