C Memory Addressing
Suraj143
Active Member
I want to point many variables to particular memory locations in a PIC.
In ASM I do as this
	cblock	40h
	data1,Data2,data3
	endc
So I know the address of each data1, data2, data3...... etc......
In C language how I point memory address?
	unsigned short data1,data2,data3
In the above I don't know the exact memory address :(
I use mikroC
Absolute addressing is done with the @ symbol. Look it up in your documentation.... But!!! The whole point of C is you don't need to know where it is..
If you get your head around pointers...
unsigned char variable;   // create variable for data..
unsigned char* location;    // create a pointer ..
location = &variable;  // point at variable..
*location = 0x22;   // assign variable..
variable now contains 0x22..
Hi thanks for the reply. Actualy I know a bit about pointers.
Actually this is what I'm going to do.Let say I get numbers from 1 to 30.This number I must store in general purpose registers.
GP registers starts (declared) 40h onwards.
If it is 1 then it must store in 41h--now it contains 1
If it is 4 then it must store in 44h--now it contains 4
If it is 12 then it must store in 4Ch--now it contains 12
In assembly I do like this.
		movf	Zone_Number,W
		addlw	40h		; add offset (because GP starts from 40h onwards)
		movwf	FSR
Place_Alarms	movf	Zone_Number,W
		movwf	INDF
I want to do this in C.
That's how I would do it... Remember that a pointer in C IS the same as the address of an array
So
unsigned  int alarm[30];
unsigned int* digit = &alarm[];
digit[zone_number] = zone_number;
Not that you'll need it in this case.... Its just easier to pass a pointer and receive a pointer when using functions...
If you want to write to memory location 0x40 you can cast that memory adress to a pointer and then write to that location:
(*((uint8_t *)0x40)) = value;
You can use that pointer as an array also:
((uint8_t *)0x40)[index] = value; // write to memory location 0x40+index.
