Please could you possibly check this XC8 C code for PIC16F1508?
All it is supposed to do is read the ADC input, and if greater than 10, then get on send PWMs on PWM1 and PWM3
(PWM T = 1ms and 50% duty cycle)
It wont build as for some reason it doesnt like the "T2CKPS" nemonic
//pic16f1508 LED COLOR mixer
// CONFIG
// CONFIG1
#pragma config FOSC = INTOSC // Oscillator Selection Bits (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = OFF // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config BOREN = OFF // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = OFF // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF // Internal/External Switchover Mode (Internal/External Switchover Mode is disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is disabled)
// CONFIG2
#pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off)
#pragma config STVREN = OFF // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will not cause a Reset)
#pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LPBOR = OFF // Low-Power Brown Out Reset (Low-Power BOR is disabled)
#pragma config LVP = OFF // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <stdint.h>
#define _XTAL_FREQ 4000000
uint16_t count;
uint16_t count1;
uint16_t count2;
uint16_t vbusmeas;
void main(void) {
//SETUP PORTS
TRISA = 0x38; //ips are temp, commsbus
TRISB = 0x00;
TRISC = 0x04;
//RA2 = PWM into RC for dimming
//RC1 = PWM DIMMING OR TURN OFF
/* PORT FUNCTIONS
RA0 = DAT
RA1 = CLK
RA2 = DIM1_UC...dim the HV9910B with PWM into RC....................
RA3 = MCLR
RA4 = TEMP input (MAKE OP LOW FOR NOW)
RA5 = COMMSBUS (MAKE IP) ***
RA6 = NO PIN
RA7 = NO PIN
RB0 = NO PIN
RB1 = NO PIN
RB2 = NO PIN
RB3 = NO PIN
RB4 = NC OP LOW
RB5 = NC OP LOW
RB6 = NC OP LOW
RB7 = NC OP LOW
RC0 = CHILICOMMS OP LOW (MAKE OP LOW FOR NOW) ..NNEDS WEAK PULLUP
RC1 = TURN OFF HV9910B (OP)
RC2 = VBUSMEAS
RC3 = NC OP LOW
RC4 = COMMSBUSDRIVE OP LOW
RC5 = COLORMIX OP LOW..................................................
RC6 = SC_OUT OP LOW (MAKE OP LOW FOR NOW)
RC7 = CURRENT MONITOR (MAKE OP LOW FOR NOW) */
//INITIATE PORTS
LATAbits.LATA0 = 0;
LATAbits.LATA1 = 0; //
LATAbits.LATA2 = 0; //
//LATAbits.LATA3 = 0; MCLR
//LATAbits.LATA4 = 0; //temp sensor input
//LATAbits.LATA5 = 1;
//LATAbits.LATA6 = 0; //NO INTERNAL PIN
//LATAbits.LATA7 = 0; //NO INTERNAL PIN
//LATBbits.LATB0 = 0; //NO INTERNAL PIN
//LATBbits.LATB1 = 0; //NO INTERNAL PIN
//LATBbits.LATB2 = 0; //NO INTERNAL PIN
//LATBbits.LATB3 = 0; //NO INTERNAL PIN
LATBbits.LATB4 = 0;
LATBbits.LATB5 = 0;
LATBbits.LATB6 = 0;
LATBbits.LATB7 = 0;
LATCbits.LATC0 = 0;
LATCbits.LATC1 = 1; //TURN OFF LED DRIVER
//LATCbits.LATC2 = 0;
LATCbits.LATC3 = 0;
LATCbits.LATC4 = 0;
LATCbits.LATC5 = 1;
LATCbits.LATC6 = 0;
LATCbits.LATC7 = 0;
//SETUP FUNCTION REGISTERS
ANSELA = 0x00;
ANSELB - 0x00;
ANSELC = 0x04; //VBUSMEAS
ADCON0 = 0x18; //choose AN6
ADCON1 = 0x40; // fosc/4, leftjust, refvdd
ADRESH = 0x00;
CM1CON0 = 0x00;
CM1CON1 = 0x00;
CM2CON0 = 0x00;
CM2CON1 = 0x00;
INTCON = 0x00;
OPTION_REG = 0x07; //wpu BY latch
WPUA = 0x10; //temperature input
WPUB = 0x00;
//WPUC = 0x81; //CURRNT MO, Chilicomms //NO WPUC
T2CON = 0x00;
ADON = 1; //ENABLE ADC
PWM1CON = 0x00;
PWM3CON = 0x00;
LATAbits.LATA2 = 0; //zero light
LATCbits.LATC1 = 1; //led driver off
while(1) {
GO = 1; //START CONVERSION
while(GO) {;}
vbusmeas = ADRESH;
if (vbusmeas > 10) {break;}
//SET UP PWM1 (RC5) FOR 50% DUTY CYCLE AT T= 1ms
//Page 253 of PIC16F1508 DATASHEET
TRISC5 = 1;
PWM1CON = 0x00;
PR2 = 0xFF;
PWM1DCH = 0x00;
PWM1DCL = 0x00;
TMR2IF = 0;
T2CKPS = 0x00;
TMR2ON = 1;
PWM1EN = 1;
while (!TMR2IF){;}
TRISC5 = 0;
PWM1OE = 1;
PWM1EN = 1;
//SET UP PWM3 (RA2) FOR 50% DUTY CYCLE AT T= 1ms
TRISA2 = 1;
PWM3CON = 0x00;
PR2 = 0xFF;
PWM3DCH = 0x00;
PWM3DCL = 0x00;
TMR2IF = 0;
T2CKPS = 0x00;
TMR2ON = 1;
PWM3EN = 1;
while (!TMR2IF){;}
TRISC5 = 0;
PWM3OE = 1;
PWM3EN = 1;
while(1){;}
return;
