Building Static Voltage Stabilizer
drjackool
Hi
I want to build a AC-to-AC (220V 25A) static voltage stabilizer like the following video. Where can find the full circuit and elements specification like that:
Solution
That looks to have some complex electronics and not something for the casual experimenter to build from scratch.
There is a non-electronic, constant-voltage transformer (Sola is a common brand), that uses a saturating transformer double core with a capacitor-coupled resonant winding to generate a constant output from a varying input, described here.
rjenkinsgb
Most Helpful Member
I've never seen one of those before.
However, from examining the wiring layout in the video, it appears to have the secondary of the power transformer in series with the input to output "live" connection.
Presumably it works by synchronising in phase to the input AC, then driving the primary of the power transformer with a sine wave controlled in polarity and amplitude to add or subtract voltage from the input supply, to maintain the correct output voltage.
It must use a high power full bridge driver, controlled by a program in the DSP MCU that monitors input and output voltage and phase, to continuously calculates the required adjustments.
It's an extremely complex unit..
crutschow
Most Helpful Member
Solution
