Building a Medical Sensor
wal99d
Good day guys,
First of all i'm going to build my own medical sensor and
i had a problem till NOW on deciding which type of sensor i'm going
to build.I mean an easy sonser with little transistors. So i apreciate
your help on that as soon as you can guys. :wink:
The following can be measured by purely non invasive electronic methods.
Pulse/ heartbeat , Blood Oxygen level,
Blood pressure - I think, (will have to check my notes to be sure)
Ultrasonics can measure blood flow.
Nerve signals , brainwaves and motor control of limbs
Internal core temperature continues to be a challenge
as does the cordless camera "pill"
What do you want to sense - temperature, pressure, resistance, voltage ?
There are several projects that I've seen described that are EKG type. They require some good ICs but didn't appear to be all that difficult to build. The simplest is a skin resistance meter - people doing biofeedback use these or build them. An air pressure sensor that with a range of 0.5 psig to 5 psig could be used to measure blood pressure - with the right mechanical and electronic accessories.
A note of caution - whatever it is that you build, if there is any normal or failure mode that could result in a fatal or injurious flow of current (or temp, pressure, etc) then you should not actually use it on someone.
