BoostC USART 18F
AtomSoft
Ok im having some trouble receiving from Hyper Terminal to my PIC18F1320.
Im using BoostC to program/
I can send data out with no problem... Here is my receive code:
void RxRecv(char &MyTmp)
    while(!pir1.RCIF);
        MyTmp = rcreg;
        Rs_Send(rcreg);
and this is how im calling it
    while(1)
        char Tmp2 = 0x00;
        RxRecv(Tmp2);
Now for some reason when i type a key in hyper terminal it wont work. But i have the same code in ASM and it works fine on same chip. Any thoughts?
The argument of the function RxRecv() looks wrong to me.
Does this work?
unsigned char MyTmp;
unsigned char RxRecv(){
    while(!PIR1.RCIF);
    return RCREG;
while(1){
    MyTmp = RxRecv();
    Rs_Send(MyTmp);
    while(!pir1.RCIF);
        MyTmp = rcreg;
        Rs_Send(rcreg);
Try changing it to void RxRecv(char *MyTmp) and your calling code to RxRecv(&Tmp2);
The (char *) tells the compiler to expect a pointer with the address of a char variable and &Tmp2 passes the address of the variable.
The actual issue is i cant seem to get passed the (bold):
    while(!pir1.RCIF);  //Not correctly checking Flag even with
                        //a breakpoint i cant skip this
        *MyTmp = rcreg;
        Rs_Send(rcreg);
yes here is my full code: (still nothing)
#include <p1320.h>
#pragma	CLOCK_FREQ 8000000
void Rs_Init()
    //RS Init.
    trisb = 0b00010010;
    portb = 0x00;
    spbrg = 0x0C;
    txsta.BRGH = 0;
    baudctl.BRG16 = 0;
    txsta.SYNC = 0;
    rcsta.SPEN = 1;
    rcsta.CREN = 1;
    txsta.TXEN = 1;
void Rs_Send (char tx_char)
    while(!pir1.TXIF);
    txreg = tx_char;
void puts(char *source)
	while (*source != 0) // wait until tx register is empty
	    Rs_Send(*source++);
        Rs_Send(0x0d);
        Rs_Send(0x0a);
        *MyTmp = rcreg;
        Rs_Send(rcreg);
void main()
    //PIC Init.
    osccon.IRCF2 = 1; // 8Mhz Clock
    osccon.IRCF1 = 1;
    osccon.IRCF0 = 1;
    Rs_Init();
    puts("Hello, world\r\n");
    while(1)
        char Tmp2 = 0x00;
        RxRecv(&Tmp2);
You did not configured the A/D channels, did you? Try adding this line at the begining of the main function:
ADCON1 = 0xFF;
Does this work?
char Tmp2 = 0x00;
while (1) {
      if (pir1.RCIF) {
         Tmp2 = rcreg;
         Rs_Send(Tmp2);
      } // end if
} // end while
Why not use an interrupt?
