No there isn't.Oh yes there is. The current source is a voltage source with a relatively large resistor. Therefore, anytime you hook up a current source to the base of a BJT you are making a transistor circuit by adding the external resistor of the current source.
Why do you make the assumption that the only way to make a current source is with a voltage source and a resistor? A current source, by itself, is just as valid a component as a voltage source, by itself, although voltage sources are more common.
One current source with no added resistance that comes to mind is a photocell.
Another is a Van de Graaff or Wimshurst generator (I'll admit that's a bit of a reach but they are current generators although that's not their normal use).
Also a superconductor inductor with a circulating current.
No added resistance needed.Yes it is a circuit due to the added resistance in the base from the current source.
Assuming that the only way to make a current source is with a voltage source and a resistor. Rather narrow minded of you.So, where did I go wrong in my reasoning?
Ping
