bjt pre amplifer design
aruna1
I have to design a multistage bjt pre amplifier with following conditions
gain 20-60dB
input impedence >= 5K ohm
output impedence <= 100 ohm
bandwidth 300Hz - 3MHz
source impedence 600 ohm
load impedence 10 K ohm
can someone please give me a good tutorial link which i can learn to design above pre amplifier?
thanks
First you need to learn about Ohm's Law.
Then you need to study how transistors work.
Then you must learn how to add, subtract and multiply numbers.
I forgot. You must learn how to read (to see the spec's of the transistors on their datasheets).
