Bizarre problem with Junebug LEDs
Gfaja
Here's the code I'm running
list p=18F1320
include <p18F1320.inc>
CONFIG OSC = INTIO2, WDT = OFF, LVP = OFF
org 0x000			; RESET vector
; INIT
INIT 	movlw b'01111110'
		movwf TRISA
		movlw b'00000001'
		movwf PORTA
		movlw b'11000000'
		movwf TRISB
		movlw b'11111111'
		movwf PORTB			; Set pullups
; MAIN
MAIN
		btfsc PORTB,RB2 ; Test button 2
		goto MAIN
		movlw b'10000000' ; Once it's been pressed switch the led and leave it
		movwf PORTA
		goto MAIN
END
it was working fine, but I changed it to use the other button (RB5). Then instead of lighting LED6 it would light LED 1 and 3, LED 6 would flicker a bit, then after about 20 seconds it would switch, 1 and 3 would go out then 6 would go on. It still responded to button presses as expected. Switching back to RB2 the problem remained.
Does anyone have any idea what's going on? Looking at the diagram I understand why 1 and 6 are on.. if RA6 is disconnected, 1 is on and 7 is off, I would expect 1, 3 AND 6 to go off, and clearly it's something to do with those three. What am I missing?
Try this:
list p=18F1320
INIT
	movlw b'01111110'
	movwf TRISA
	movlw b'00000001'
	movwf PORTA
	movlw b'00100101'    ;Proper port tris setup now (1 = input)
	movwf TRISB
	movlw    0x80
	movwf    INTCON2     ; Set pullups
	movlw    0x7F
	movwf    ADCON1      ; Set to all digital
MAIN
    goto MAIN
    movwf PORTA
    goto MAIN
END
Info in datasheet:
pullup-jpg.30924
Using the above note from datasheet you can see to enable pullups:
	movlw    0x80
OR
	bsf    INTCON2,RBPU     ; Set pullups
And since RB4:RB0 are auto set to ANALOG on startup it will always read as a 0 until you set it as digital:
In datasheet and junebug manual:
RB0 = SW1
RB2 = SW2
RB5 = SW3
Now to figure how to set ADCON1 you have to find this:
I edited the image so you can see how the registers line up so you can see which PortB pins have what name in ADCON1 register. So you can then:
	movlw    0x7F
or just set the ones you need RB0, RB2, RB5:
	movlw    b'00100101'
	movwf    ADCON1      ; Set RB0, RB2, RB5 digital for button input.
Ahh ****.. I even read up on adcon, but I guess I was too used to my arduino.
Why is it adcon1, and not just adcon?
And thirdly.. New code makes perfect sense, except why aren't we setting bit 7 in adcon1?
And finally.. I'm still not exactly sure why the junebug was acting like it was.. it still doesn't really make sense to me and the inconsistency is the weirdest. What does writing to an input pin do?
From the datasheet section 17:
17.0 10-BIT ANALOG-TO-DIGITAL CONVERTER (A/D) MODULE
The ADCON0 register, shown in Register 17-1,
controls the operation of the A/D module. The
ADCON1 register, shown in Register 17-2, configures
the functions of the port pins. The ADCON2 register,
shown in Register 17-3, configures the A/D clock
source, programmed acquisition time and justification.
So basically it is the registers name.
ADCON has to do with the Analog to Digital Conversion(ADC). And selecting which pin to read.
ADCON1 has to do with setting the PINs to Digital or ANALOG.
ADCON2 has to do with the timing of the ADC.
Why not set bit 7 of ADCON1:
because this is its purpose: "Unimplemented: Read as ‘0’"
It has no use. Its not used.
Writing to a INPUT pin: i have no clue what would happen... i assume nothing :)
arduino is more of a shortcut thing i think. You miss out on a lot i suppose. Like the basic stamp. You never get full control. Like of every register. Of course its harder this way but way more satisfying and precise.
Yeah I'm using the arduino for simple robotics and stuff but using pics for smaller more integrated things as well as to make something w/out feeling like I cheated. Arduinos are TOO easy.
Hm now it started randomy switching to LED 5 immediately after starting up now, when it should be LED 6 until I hit the button
; *** Junebug 18F1320 LED sequencer demo ***
; Flashes LEDs1 thru 6 from left to right forever
; DIP Switch (SW6) must have TUTOR on (SW6-1,2,3) all other switches off
list p=18F1320
; INIT
		movwf TRISA
		movlw b'00000001'
		movwf PORTA
		movlw b'00100101'
		movwf TRISB
		movlw 0x7F
; MAIN
MAIN
		btfss PORTB,RB2
		goto MAIN
		movlw b'10000000'
		movwf PORTA
		goto MAIN
END
Have to bump this.
Haven't touched my junebug in a while, so it's running the code in the above post.
It won't connect anymore, resetting gets the right LED lit but plugging it in make it quickly switch to what should be lit only after pressing the button. Program also completely ignores button presses. Maybe I screwed up soldering in.
Video is posted and pictures of my soldering job. Any ideas what I could have done wrong?
2
3
Nope. Yellow is dimly lit. Now I consistently get the USB not recognized message when plugging it in.
Hmm remove the 18F2550. Is there a color dot painted on the bottom?
A programmed Junebug only needs power & a working crystal (plus the pushbutton) to get the LED flashing.
sigh.... the chip was barely in the socket..
one of the indents is white?
put it back in and it flashed red and is updating its software right now. yellow is off.
Now have it running, but still have it so LED 5 is light a split second after LED 6 as if I had hit the button. That or it switches randomly/not when I press the switch. So basically the videos are still accurate other than the programming problem. Any ideas?
Yep the dot means I programmed it. You have to push down pretty firmly on that machine socket.
Since the Junebug sounds like it's ok, IMO it would be an excellent time to give the debug mode a spin.
Add the two following lines to the beginning of your code (else the debug mode is really slow)
movlw 0x72
movwf OSCCON
This will speed up the PIC to 8MHz
Then simply pick the debug mode instead of the program mode. You can single step , run , animate, set breakpoints and watch variables.
TIP open a "watch" window and watch PORTB & TRISB
You can toggle bits directly in this mode and see the results directly on the LEDs.
Ah ok. I will do that. I had a problem with only being allowed one breakpoint, and it was super slow, I assumed it ran by default on full speed.
The default internal osc speed is 31.25 kHz, good for flashing LEDs but really slow for the debugger.
I started out with a Parallax Clearview 5x ICE for the 16C54 way back before debuggers were available.
Hm, I get popups for stupid things,
Stepping Target
PICkit 2 Ready
Stepping Target
PICkit 2 Ready
Stepping Target
PK2Error0029: Failed PICkit 2 operation: Step
Running Target
PK2Error0029: Failed PICkit 2 operation: Halt
PICkit 2 Ready
Target Halted
It fails the step when it's on the movwf TRISB and the bsf is the next command (consistently)
Hmm make sure DEBUG is enabled (from the MPLAB pulldown) and change TRISB bits 6&7 to 1.
movlw b'11100101'    ;Proper port tris setup now (1 = input)
movwf TRISB
