Binary clock (to be finished 4 real)!
  • Thread starter Robot builder 101
  • Start date
R
Robot builder 101
Guest
This is a project that I am ACTUALLY! going to start and finish. I found a thread already, and it looks like I can substitute the timing module with a 555 at 1 hz. The stuff used for the 1hz (actually 1.000000000000001 hz) is 10k resistor, 100k resistor, and a 10uf cap. It looks kind of easy to connect, but I may need some help.
https://www.electro-tech-online.com/threads/binary-clock.98/?highlight=binary+clock
sorry for the long I-net (did apple use this one already? inet?) adress.
Bear in mind a 555 based clock will keep absolutely pathetic time!.
If you use a advanced CMOS timer, like the 7555 (It is a cmos and low voltage right?) and good filter caps, you may be able to pull it off.
Still be utterly crap! :p
Use a 32KHz crystal (watch crystal) and a divider!.
Here's one I'm planning on doing sometime soon (but 5 volts and probably a 16F628A)...
I am going to order the parts that i need. The only question I have is: can I substitute CMOS (HC series) for TTL (LS)? The LS series has low output, but just to be safe i want to give it morepower.
If you can find the parts as cmos, you can use it! I read that you like jameco, and jameco doesnt supply the 74LS90/93/86/279 as HC. Good luck
This is how you can achieve a stable 1Hz clock using only one IC and no programmable components.
1-hz-png.10810
Would a 20mhz crystal work or would I have to use the watch crystal. I am builidng one too and I just ordered the parts.
A 20MHz crystal doesn't divide down nicely to 1Hz, the 4.xMHz one above does, and so do the (so called) 32KHz watch crystals - and these are also better time keepers than the higher ones, as they are specifically intended for clock use.
Wow Moore's law even applies to atomic clocks.
