I try to control speed of 12V DC, 5A bilge pump through my PC soft and KBIC-120 variable speed drive. There is a range of applied voltage from the drive
3 to 12V DC. There is a fuse 8 Amp between pump and drive. When it starts, the fuse burns out. I've tried to use 10 Amp fuse and after several minutes pump motor burned out. I've already tried the same way, but with regular
12V DC car fan and everything worked perfect. I understand that when the pump works with load it takes more current. How to resolve this problem?
Need advise.
Thank you
Need advise.
Thank you
