Beginners question on parallel circuit
mongoose_gef
I'm having an issue creating a parallel circuit with some small LED's. I'm using 470 ohm resistors and individually the LED's work, however when I put them in parallel at 5v the flicker or just don't come on. The picture show the set up with some temporary electrical tape to prevent shorting
What is the supply voltage measured when they are all connected ?
Is what you call parallel like this ?
(+)-----------------------resistor----------------LED--------------------(-)
I'm reading 5v between soldered rails. I modelled my circuit after this
** Mod edit.. Faulty link removed**
A positive rail that all resistors are attached and a negative rail for the negative led.
