BCD Problem
alamy
Hi...
i'm looking to binary to decimal conversion, BCD...i search at piclist and found it.
but looking to the code, i come across 'new' code there..pls explain
this code convert 4bit to BCD 2 digits.
Input:
W is a binary number in the range 0..29
Output:
W is a BCD number in the range 0x00..0x29
; W is 0..29
    addlw    .256-.20        ; C will be set if number was >= 20
    skpnc
    addlw    .6                   ; ...adjust for 20..29
    addlw    -(.256-.20)    ; Back to original value
    addlw    .256-.10       ; C will be set if number was >= 10
    skpnc
    addlw    .6                  ; ...adjust for 10..29
    addlw    -(.256-.10)   ; Back to original value
skpnc?...what it's?
thank you in advance
apparently there are more than the 36 instructions we are used to..
Table B.11: 12-Bit/14-Bit Core Special Instruction Mnemonics (Continued)
They are not actually instructions, but a kind of macro command, or even just a 'define', they simply get replaced by one or two lines of assembler code as the assembler runs.
As with everything else, they are all listed in the MPASM helpfile - this should be the first place to look for anything to do with the MPASM assembler!.
