Battery / Voltage Regulator
danos
Hello everyone....
I really need to build a voltage regulator and i need ur help and ideas about any kind of design...
Basically, i need a voltage regulator from 36V battery to 24V
Thanks in advance
danos said:
Hello everyone....
Thanks in advance
What are your current requirements? A 78L24 can produce 24V @ 100mA. An LM317K can produce between 1.2V and 37V @ 1.2A. An LM317T can produce between 1.2V - 37V @ 1.5A. An LM338K can produce between 1.2 - 33V @ 5A.
From what i know should be a bit more than the 5A
might be 6 or 7A
Sorry, i forgot to mention!!
Thanks for ur reply
You can use any of the above with an external pass transistor. Check their datasheets. That would be a whopper of a transistor, though, because you're looking at 84 Watts of power dissipation just across the transistor. Think "switcher."
j.
36 volts,
sounds like three 12 v batteries to me.
the easy way would probably be to
put the wire on to the 24 v connection.
simple and effective.
