magnetman12003
I have a 30 volt peak to peak function generator powering a large experimental motor coil with its square wave output. 0 - to 30 volts as the max the generator can put out. I am working with variable hi frequencys also.
So far I have been lucky and have not damaged the function generator output with back EMF voltage spikes coming out of the coil its powering. The generator is the sole power source right now.
Stating all the above -- Does anyone have or know of a circuit that will prevent back EMF from damaging the output of the generator yet allow the generator to keep supplying voltage to the coil at the same time?
I need a block diagram schematic with all parts called out to construct that device. Is this possible??
If so please send that info direct to me at: 65t@comcast.net
Thanks, Tom
Thanks, Tom
