hello every one and i hope they all ok could u help me
A temperature sensor is to be interfaced with a PC and an output signal is to control the flow of hot air into the room. A high level language
could i use by this way , by use PIC 16F877 and i thing this chip because there is A/D (analog to digital)convertor.and the PIC 16F877 it will read the temperature from temp sensor LM35 , i thing this LM35 because it's more sensitive to tempreture and the output is constant 10mv/1c and it's linear , then it will convertor to digital then send to PC by serial port.
now the problem i do't know how to do the program in a high level language?
is this my way right. and how to do the program?
thank you very much
best regards
thank you very much
best regards
