atmega 32 sample code
This may help for starters and is this thread related to the other thread you started? You already have this thread going.
Also some of your questions would likely be better served in the micro controller sections of the forums.
Ron
These are codes in mikroBASIC I made when I was learning the AVR.
BASIC A-D conversion:
program ADC_Test
main:
     DDRB = $FF
     DDRD = $FF
     DDRC = 0
     ADMUX = 0
     DIDR0 = $3F
     ADCSRA = $85
     while true
           ADCSRA.ADCS = 1
           while (ADCSRA.ADCS)
           wend
           PORTB = ADCL
           PORTD = ADCH
           delay_ms(2)
     wend
end.
ADC controlled by Timer and interrupt:
program ADC_int
dim done as byte
sub procedure ADC_Int() org $015
    PORTB = ADCH
end sub
sub procedure TMR0_Int() org $010
    ADCSRA.ADSC = 1 'ADCSRA.ADSC 'START CONVERSION
end sub
main:
     DDRB = $FF 'ALL OUTPUT
     DDRC = 0 'ALL INPUT
     TCCR0A = 0 'NORMAL OPERATION
     TCCR0B = 3 'PRESCALER 64
     SREG = $80 'GIE
     TIMSK0 = 1 'ENABLE TMR0 INTERRUPT
     ADMUX = $20 '8-bit, CH0
     DIDR0 = $3F 'ALL ANALOG
     ADCSRA = $8D 'ADC ON, INTERRUPT ENABLED, FOSC/64
     while true
     wend
end.
ADC on LCD (with mikroBASIC library function):
program ADC_LCD
symbol RW = PORTB.B1
symbol RW_Direction = DDRB.B1
dim LCD_RS as sbit at PORTB2_bit
dim LCD_EN as sbit at PORTB3_bit
dim LCD_D4 as sbit at PORTB4_bit
dim LCD_D5 as sbit at PORTB5_bit
dim LCD_D6 as sbit at PORTB6_bit
dim LCD_D7 as sbit at PORTB7_bit
dim LCD_RS_Direction as sbit at DDB2_bit
dim LCD_EN_Direction as sbit at DDB3_bit
dim LCD_D4_Direction as sbit at DDB4_bit
dim LCD_D5_Direction as sbit at DDB5_bit
dim LCD_D6_Direction as sbit at DDB6_bit
dim LCD_D7_Direction as sbit at DDB7_bit
dim Value as longword
dim Disp as word[3]
dim sValue as string[5]
dim sDisp as string[5]
main:
     RW_Direction = 1
     RW = 0
     LCD_Init()
     LCD_Cmd(_LCD_CLEAR)
     LCD_Cmd(_LCD_CURSOR_OFF)
     LCD_Out(1, 1, "Reading:")
     LCD_Out(2, 1, "Voltage:")
     sDisp = "4.99V"
     while true
           Value = ADC_Read(0)
           WordToStr(Value, sValue)
           LCD_Out(1, 10, sValue)
           Value = (Value * 500) >> 10
           Disp[0] = (Value div 100) + 48
           Disp[1] = ((Value div 10) mod 10) + 48
           Disp[2] = (Value mod 10) + 48
           sDisp[0] = Disp[0]
           sDisp[2] = Disp[1]
           sDisp[3] = Disp[2]
           LCD_Out(2, 10, sDisp)
     wend
end.
Hope this helps.
Tahmid.
Hi to all :-)
My name is kike and i'm begginer into Atmega family microcontroler, i need to do a convertion of 3 signals of a ADXL 330 accelerometer. For to do this job, i am using a ATmega32 that have a ADC 8-channel multiplexer, the programing is in assembler. Have someone worked with more than 2 signals?, i am confused of how to programing the both ADMUX and ADCSRA registers.
If someone know how to work with the ADMUX and ADCSRA register, please help me :-( .
see you, and thank you.
