samcheetah said:could you explain your question a little bit? why do you want to use something other than the widely accepted MPLAB development package. i read somewhere that PIC can be programmed in about two dialects of assembly language; MPASM and TASM (or something like that). MPLAB contains the MPASM assembler and it works great. why would u want to migrate to another dialect of assembly. if u do want to try something else, try a high level language like C.
is it fixed ?amady said:samcheetah said:could you explain your question a little bit? why do you want to use something other than the widely accepted MPLAB development package. i read somewhere that PIC can be programmed in about two dialects of assembly language; MPASM and TASM (or something like that). MPLAB contains the MPASM assembler and it works great. why would u want to migrate to another dialect of assembly. if u do want to try something else, try a high level language like C.
This is because i got the problem when to generate the .hex file... the error is : succeded the 62 characters...
atferrari said:As far as I know, the path to the directory where the project is located should be less than 62 chars in length.
In my laptop and my PC at the bench I put the project file in the Desktop (WIN 98SE and WIN ME).
Hope this solve that awful problem.
Agustín Tomás
amady said:Thank you atferrari it work's.. i was put at my C directory...
samcheetah said:amady said:Thank you atferrari it work's.. i was put at my C directory...
im glad things worked out for you. actually im really frustated with this type of error. the first time i started using MPASM i always got this error but then i read the error carefully and then consulted the help file. and voila!!!!!! i figured the solution. so the next time you get some error think about it a little bit and dont go for throwing out the software
i dont like the color ..too darktechknow said:Hey i need some help on my projects...i am trying to make a 7segment display based clock...i also have a forum www.varunulaa.com/forum in there i have posted some of my projects so ppl join they too to help.......
techknow said:Does anyone have a simple asm code for LCD and PIC16F628 interface...cause i got some big codes..damm ..so i need an simple one which can print an "hello" word. cause i am also a biginner for microcontroller programing from asm. and i use MPLAB and ICPROG..i hope u guys will get me a good working and simple asm code for LCD intreface. any way thanks for willib
techknow said:Do u need the circuit diagram of my picprogrammer or the software...
