asm file to HEX file
i got some asm. file that i want to test
software is PICgm
but the programmer cant upload
i think the must be at HEX. format
what should i do ?
here :
; traffic light simulator (3 LEDs with 4 combinations) using outputs muxed on GP0 and GP1.
;  Internal pullups used on GP2, GP4, and GP5.
;  GP3 is pulled up
	list      p=12f629            		; list directive to define processor
	#include <p12f629.inc>        		; processor specific variable definitions
	errorlevel  -302              		; suppress message 302 from list file
	__CONFIG   _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
;***** VARIABLE DEFINITIONS
flags		EQU		0x21		;bit flags 0=has timer0 interrupt delay happened?
delay1	EQU		0x22
delay2	EQU		0x23
loop1		EQU		0x30		;tmr0 delay counters
loop2		EQU		0x31
cnt1		EQU		0x32		;tmr0 delays
cnt2		EQU		0x33
;***** CONSTANTS
lp1			EQU		8		;initial timer0 delays
lp2			EQU		4
interrupt	EQU	0
L_red	EQU	0
L_green	EQU	4
L_amber	EQU	2
L_redamber	EQU	6
Delay1	EQU	0xF0
;***** MACROS
bank0:  MACRO
        bcf STATUS, RP0
        ENDM
bank1:  MACRO
        bsf STATUS, RP0
        ENDM
delay:  MACRO
        call Delay
        ENDM
;***** PROGRAM CODE
		ORG     0x000					; processor reset vector
		goto    Main					; go to beginning of program
		ORG     0x004					; interrupt vector location
Interrupt
		btfss		INTCON, T0IF			; only concerned with TMR0 interrupts
		goto		IntDone
		bcf		INTCON, T0IF
		decfsz	loop1, F
		goto	IntDone
		movf	cnt1, W
		movwf	loop1
		decfsz	loop2, F
		goto	IntDone
		movf	cnt2, W
		movwf	loop2
		bsf		flags, interrupt			; mark delay has occurred
IntDone
		retfie							; return from interrupt
Main
		movlw	lp1				; initialise interrupt variables
		movwf	loop1				;
		movwf	cnt1				;
		movlw	lp2				;
		movwf	loop2				;
		movwf	cnt2				;
		bank1
		movlw	b'00001000'		; set TRISIO, all output except GP3
		movwf	TRISIO
		movlw	b'00110001'		; set weak pullups
		movwf	WPU
		movlw	b'00000101'		; enable internal pull-ups and set pre-scalar
		movwf	OPTION_REG
		movlw	b'10100000'		; use TMR0 and disable all other interrupt sources
		movwf	INTCON
		bank0
; main loop
Loop
		movlw	L_red
		movwf	GPIO
		delay
		delay
		delay
		movlw	L_redamber
		movwf	GPIO
		delay
		movlw	L_green
		movwf	GPIO
		delay
		delay
		delay
		delay
		movlw	L_amber
		movwf	GPIO
		delay
		goto    Loop
; **** subroutines
Delay
		movlw	Delay1
		movwf	delay1
Pause
		btfss		flags, interrupt
		goto	Pause
		bcf		flags, interrupt
		decfsz	delay1, F
		return
		goto	Pause
		END                  	     	; directive 'end of program'
some attachment :
:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
thanks , eric
Check this part of your program
This is the correct sequence, runs well on Oshonsoft.
L_red    EQU    1
L_redamber    EQU    3
L_green    EQU    4
L_amber    EQU    2
  • trans2.zip
my first PIC programming :D:D:D
Thanks to eric for translating my Asm. file to hex
at the plan the led is need to be at least three but because of the limit of my led
i only use 2 led ( i already have 2 amber led on that time , now i already have many )
it hard to post on youtube , i think it need 2 days ( im not lie ) :D
and also see my blogger **broken link removed**
ok then enjoy it :D
could you post that again (post #18), transistorman?
it doesn't appear well actually
hello, transistorman so you are from indonesia
nice to meet u here
btw where can i get the picgm software?
thx
bluesam
i allready edit it ( i dont know how to post video :D )
you can get PICgm at **broken link removed**
and its FREE :D
EDIT: i not using IC-Prog because i dont know how to setting it
plus , i allready get PIC16F877A :D:D:D:D
i will bought my PIC programmmer soon :D:D
