Arduino Code Problem
Mike - K8LH
Hi guys. I'm trying to copy a bit in a local variable to another bit position within that variable but so far "no joy". Basically I'm trying to copy bit 6 in the "hi" variable to bit 7 but none of the instructions I've tried are recognized by the compiler (the size of the compiled program doesn't change and there are no error messages). Please help?
TIA... Cheerful regards, Mike
   *  Flash_v1    (28C256 EEPROM Programmer)                        *
   *  Mike McLaren, K8LH                                            *
   *  Micro Application Consultants                                 *
   *  02-Dec-2020    Arduino 1.8.13 / Arduino Uno                   *
   #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~(1<<bit))  // clear bit
   #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= 1<<bit)     // set bit
   *  variables & constants                                         *
   #define A15    PORTB1
   #define CE     PORTB2
   #define OE     PORTB3
   #define WE     PORTB4
   uint32_t address = 0x0100;
   const char hex[] = "0123456789abcdef";
   void setAddr(uint32_t addr)  // hard coded for 28C256
   { byte hi = (addr >> 8) & 0x7F;  // A14..A8 bits
     byte lo = addr & 0xFF;
   *  set data bus lines to outputs
     DDRB |= 0x03;              // PB1..PB0 (D7..D6) Outputs    ( 6)
     DDRD |= 0xFC;              // PD7..PD2 (D5..D0) Outputs    ( 6)
   *  strobe latches with address hi (A15..A8)
     if(hi >= 64) { hi |= 0x80; }                <------------------------------
     PORTB = (PORTB & 0xFC) | (hi >> 6);
     PORTD = (PORTD & 0x03) | (hi << 2);
     cbi(PORTB, OE);            // OE(PB3) = 0                  ( 2)
     sbi(PORTB, OE);            // OE(PB3) = 1                  ( 2)
   *  strobe latches with address lo (A7..A0)
     PORTB = (PORTB & 0xFC) | (lo >> 6);
     PORTD = (PORTD & 0x03) | (lo << 2);
     DDRB &= 0xFC;              // PB1..PB0 (D7..D6) Inputs
     DDRD &= 0x03;              // PD7..PD2 (D5..D0) Inputs
   *  main                                                          *
   void setup()
     sbi(PORTB, CE);            // CE(PB2) = 1
     sbi(PORTB, WE);            // WE(PB4) = 1
     DDRB |= 0x3C;              // CE/OE/WE/A16 Outputs
     DDRC |= 0x30;              // PC5(A18)..PC4(A17) Outputs
     Serial.begin(115200);      //
     Serial.print(F("EEPROM Test "));
     Serial.println();          //
   void loop()
     if(Serial.available())      //
     { Serial.write(Serial.read());
       setAddr(0x0100);
