JAMES IRVINE
Does anyone know of any free or reasonably priced power electronics simulation software to enable me to simulate a DC to AC Inverter. I've found loads of free software but none for this purpose.
JAMES IRVINE said:Does anyone know of any free or reasonably priced power electronics simulation software to enable me to simulate a DC to AC Inverter. I've found loads of free software but none for this purpose.![]()
hi Mike,Pommie said:
JAMES IRVINE said:you always make me feel so happy Uncle Scrooge, you know how to cheer me up.
Eric I was wondering if you have any tips on using the software as it's really mind blowing to me just now and I'm running out of timeuntil my deadline on the 9th may. For example how do you designate a resistor as the load resistor so as the simulation knows where your output is supposed to be (or how do you designate the sampling point) and the other thing I can't fathom is how to select a centre tapped transformer.
No.JAMES IRVINE said:I'm making two assumptions from what I've understood so far and that is that seeing as you mentioned the 50-50 duty cycle it will be operating in monostable mode.
There are many ways to make a square-wave oscillatior. These two circuits use digital inverters or gates plus many resistors and capacitors.
A CD4047 IC is an RC oscillator plus a digital divider. It has two outputs that have "perfect" 50-50 duty-cycle square-waves that are 180 degrees apart and are perfect for driving two N-channel Mosfets that drive a center-tapped transformer. It uses a single resistor and a single capacitor.
The center-tap is connected to +12V and each opposing end connects to the drain of a power Mosfet or the collector of an old power transistor. The Mosfets or transistors are driven to ground in opposition which creates a high current square-wave in the transformer.
The transformer without a center-tap needs push-pull drivers at each end of the winding so that AC flows. One wire is driven to +12V while the other wire is driven to 0V, then they reverse.
