Amplifying Output to Vcc Signal
Electroenthusiast
Active Member
I have an output from an IC, the output is considered from Output PIN to Vcc Pin of the IC. I need to Amplify this signal. Can i use a normal bias technique?
I havent tried something like this before.
hhda-jpg.44852
Edit: Any example(Diagram) for this type amplifying?
Hi all,
In any Transistor amplifier circuit in common emitter mode;
Lower terminal is connected to ground and the other one is connected to base.
So in this case Vcc to Base; and Output terminal of IC as ground.
Wouldnt the signal that i need amplify be shorted to ground, if i do like that?
Hi all,
hi again RV,
Common Emitter amp, emitter to 0V, Collector to Vsupply via a resistor, Base to the driving source via a resistor
hi eric,
i've posted a pic...
The problem here is that i'm using the same voltage source.
The Picture will describe my prob.
hi eric,
hi RV,
I am sorry I do not fully understand your question.
I have looked at you diagram without success.
its ok,
i'll find a better way to project my question.
i need a diagrammatic representation for it...
will do that, n then post here!
Hope, this is clear...
I want to amplify the signal, which is tapped between the
Output Terminal and Vcc Terminal
Don't connect with a short, but use a resistor. If this is just a digital signal, choose a resistor that will give your base current to 1/10 of collector current. If it's analog, then tell us the input/output/amplification parameters, and the output impedance of the IC, if you know it.
Is the output pin described as "open Collector output" (current-sink)?
