awesomelumens
haha I should purchase a bicycleHi again AL,
You may be interested in reading this thread @ https://www.electro-tech-online.com/threads/12v-bicycle-trailer-sound-system-details.149152/
spec
spec
well as I told that the requirement was to get some special bass. But I have tested a compression speaker with 12" one combined and sounds are terribleCan you indicate which of the following you are talking about building:
(1) Bass sub speaker
(2) 2 of mid/high speakers
(3) Bass amplifier
(4) Mi/high amplifier
(5) Bass filter/combiner
spec
Thanks in anticipation.. Do comment that can sound be made as clean as from laptop out of lm1875. If you have a tested circuit/thread, I would feel interested to read it.
woah...It would be fine adjustment. I dont have DAC now but I wil get one in near future. Till then I have installed a bass booster in my phone. And added active tone control to my amplifier.Your best bet is to do the following:
STAGE 1
(1) Store you audio as digital audio files, MP3, but preferably FLAC, in a folder on your PC.
(2) Download and install J River Media Jukebox (free)
(3) Get that all working so that you can play the audio files on your PC's speakers by using Media Jukebox.
(4) You can also play back music from CD/DVD
STAGE 2
(1) Buy a USB audio DAC ($10 upwards) that will output good quality audio, depending on the quality of the source files.
(2) Buy a 100W RMS stereo audio amplifier, possibly second hand
(3) Buy a pair of speakers, possibly second hand (look for good mid frequency and high frequency quality)
STAGE 3
(1) Connect one of the USB sockets on your PC to the USB socket on the USB DAC
(2) Connect the analog output from the USB DAC to the input of the amplifier and listen to the music
STAGE 4
(1) Buy a bass sub with built in amplifier, possibly second hand, and connect the two inputs to the left and right channels from the USB DAC
And you are done.
You can then crank the base up and down either in Media Jukebox and/or by adjusting the volume control on the bass sub.
spec
I was asking it for my computer speakers. They have dead bass. When I connected its speakers to big amolifier with volume down, they rocked the room. Will the datasheet diagram work good. Any ideasAn amplifier based on an LM1875 can be bought quite cheaply and while that will give a nice pleasant sound it will not crack your foundations.
spec
I am sure the LM1875 will sound fine, but I don not like bridge amplifiers as they introduce more distortion and can get into a tangle with some music and difficult-to-drive speakers. There are much better integrated amplifiers.I was asking it for my computer speakers. They have dead bass. When I connected its speakers to big amolifier with volume down, they rocked the room. Will the datasheet diagram work good. Any ideas
I think you have missed the point that you can get much better audio quality from digital audio files by using an external DAC and you can adjust the bass and all other frequencies with the graphics equalizers built into an audio media players, which are free. Media Jukebox, in my experience, is the best sounding all around audio media player. You can also download VLC Media Player for all other media files, mainly video, which similarly has a nice sound and is free.woah...It would be fine adjustment. I dont have DAC now but I wil get one in near future. Till then I have installed a bass booster in my phone. And added active tone control to my amplifier.
We know from speaker impedance plots vs f that impedance is an average and depends on both the sound pressure and electrical impedance. I checked a 6" full spectrum speaker on an LCR meter and recorded at 120Hz 2.5 Ohm 80uH and at 1kHz 2.5Ohm and 800uH. I might expect like a linear motor the no load impedance to rise and pressure loaded impedance to drop. except for a motor the DCR would be 10 to 20% which implies a start surge current of 5 to 8x max rated current.Tony,
I have always wondered about the damping factor figure and suspect it is purely a marketing ploy, but please correct me if I am wrong:
To a first approximation, a loudspeaker comprises a perfect solenoid (motor) in series with a resistor. That resistor is pretty much the characteristic impedance of the loud speaker so, by definition, the lowest effective output impedance seen by the solenoid (the motor) is the value of the series resistance. So, it follows that the actual damping factor, influencing the solenoid is likely to be around 50.
To further support this, the efficiency of a cone loudspeaker is only around 5%, at very best so this implies very loose coupling between the amplifier output and the loudspeaker motor.
When I was a sprog an old (probably 40) audio engineer explained this to me and I never forgot it; what is your view?
spec
Yes, I should have said when you connect a battery across a speaker.A battery has a fairly low resistance so when it is connected to a speaker you should hear a damped "thud" and when it is disconnected you will hear an undamped "bong".
Perhaps you have messed up two different situations. Cheeky means excessively loud but amusing. I asked for can I get synthetic bass of a type i.e if I love a bass of a particular song and I can tune my amplifier to give that bass on other songs too. While omitting their original bass. The big amplifier is of big size and paired up with bigger speakers. I cant place it near computer nor it is free. I have a 19 v supply for lm1875. I can also make supplies with 24-30 volts. Compression driver is sometimes used with large speakers in place of or combined with tweeters.You say you want "cheeky" bass. What is that?
You want "synthetic" bass at only one frequency that sounds like the resonance of a very cheap speaker. It sounds very bad.
You say that your computer speaker system has "dead bass" but its speakers sound good when connected to a big amplifier. Then if the speakers are not overloaded by the big amplifier then use them with a big amplifier. An LM1875 produces up to 21W into 4 ohms or 8 ohms when it has a 50V power supply. Your computer speakers might be destroyed with more than 5W.
What is a "compression speaker" and what is "combined sound"?
