adaptation of impedance to a headset
Daniboy
Hello
I need to do an adaptation of my headSet (sennheiser hs230) to work in a radio System.
The mic of the old handset is of coal and the new one I think is dynamic!
So...
in the 2 pin's I have:
Open circuit = -12V / 12V
The old Circuit with the handset = 5,8V
I hope anyone can help me!
best Regards
Daniboy
I think you mean that the old microphone is a carbon microphone (not coal!).
What radio is so old that it uses a carbon mic?
Ok you Right.
it's carbon microphone and in fact is not a radio but a console to a radar navy operator.
So the equipment brings a handset and a footswitch, but the operators wants a headset! So if I can change one headset, change the plug I will be happy.
thank's again
Daniboy
Not a simple change I think.
The carbon mic requres an excitation voltage (the +/- 12v you measured), the dynamic mic does not.
The carbon mic will have a much higher output voltage than the dynamic. I think you will need an amplifier.
The easy solution, modify a headset to use a carbon mic.
So you propose that I use a Amplifier (do you have eschematic circuit?), or change the headset to one that use carbon mic.
The second option is clear but is more expensive (I've buy this one) and I think is not common headset with carbon mic.
