AD conversion in a PIC18F2550
Thank you very much for all your responses and help so far to my question. I am humbled by your generosity.
Here is the state of things in my project so far.
I have managed to write a ADC program for my pic, compile it and write it in the PIC18F2550.
I am just not sure if the ADC is working or not.
Can someone please take a look and tell me if and what I am doing wrong??
First, a program that reads the analog value from AN0 and display it as 4 leds in binary (somehow the leds are always on)
*  This is a ADC conversion program for the  MPLAB C18-Lite compiler
*  Continuosly sample analog input
*  copy value to 4 leds
*   this program is made for the PIC18F2550
* PIN assignments:
*           AN0 :  voltage to be measured
*           RB0-3:  output LEDs (RB3 is MSB)
// Includes
#include <p18f2550.h>
#include "adc.h"
unsigned int ADCResult=0;
/********************CONFIGURATION**************/
#pragma config FOSC = INTOSCIO_EC //Internal oscillator, port function on RA6, EC used by USB
#pragma config WDT = OFF //Disable watchdog timer
// Pin assignments
#define LEDS PORTB  // output LEDs in port B
/**********MAIN PROGRAM*************/
void main()
 unsigned char channel=0x00,config1=0x00,config2=0x00,config3=0x00,portconfig=0x00,i=0;
  // initialization
  TRISB=0b110000;    // configure RB0-RB3 as outputs
  // configure ADC
  config1 = ADC_FOSC_RC | ADC_RIGHT_JUST | ADC_2_TAD ;
  config2 = ADC_CH0 | ADC_INT_OFF | ADC_REF_VDD_VSS ;
  portconfig = ADC_1ANA ;  // Only A0 is analog. the rest are digital (so as to allow us digital output on B)
  OpenADC(config1,config2,portconfig);
  // main loop
  while(1)
      ConvertADC();   // start conversion
      while(BusyADC()); // wait for result
      ADCResult=(unsigned int) ReadADC();
        LEDS=ADCResult>>6; // copy highes nybble (6 since this is a 10-bit ADC)
//  LEDS= ADRESL>>4; // copy high nybble of result to LEDs (this is for 8-bit ADC)
 CloseADC();         //turn off ADC
2. A program that converts the value from ADC to angles (0 to 320 degrees) and based on that turns on or off a led (somehow, the led is always on)
*  This is the LED-on/off based on ADC conversion from a potentiometer program
*  (compiled with MPLAB C18-Lite compiler)
*  Continuosly sampled analog input
*  based on the value from that input (after ADC) the LED is going to be
*  turn ON/OFF,
*   The range of value of the 10-bit ADC is 0~1024 which correspond to a voltage 0~Vmax
*   The range of motion of the potentiometer is 320 degrees
*   We have to make a conversion between degrees and values of the ADC
*     ZERO DEGREE  ---->  0
*     320 DEGREE   ---->  1024
* PIN assignments:
*           RB3:  output
/*********************Includes********************/
#include "adc.h"
double  angle=0;
/**********PIN Assignment*************************/
#define LEDPin3   LATBbits.LATB3  // the only one we will be using
/***********Other Definitions************************/
#define  LOWANGLE   45
#define  HIGHANGLE  135
#define  TOTALANGLE 320
#define  TOTALADC   1024
#define  CONVADCTOANGLE  (TOTALANGLE/TOTALADC)
#define  CONVANGLETOADC  (TOTALADC/TOTALANGLE)
void main()
  // initialization
   LEDPin3=0;  // turn off the pin
  // configure ADC
  // main loop
  while(1)
     angle=ADCResult*CONVADCTOANGLE;   // we get the angle here.
     if(angle>HIGHANGLE) // turn off the LED
        LEDPin3=0;   // turn off the LED
     if(angle<LOWANGLE)  // turn on the LED
        LEDPin3=1;
Can someone please tell me what am I doing wrong?
Thanks a lot again
Kansai
Basically the LEDs are not displaying correctly.
The compilation is quite good, no errors at all.
I tried to reflect in b 4 LEDS the binary value of the AD conversion and that doesnt work.
And in the other example I wanted to turn on and off the LED based on the value of the AD and that doesnt work either. basically the leds just stay ON
I have used another program to check if the AD is being performed (toogle a LED after every AD conversion) and if I put a delay it works. so I guess the AD conversion is taking place. I just dont know why the results are not being relfected in the previous programs...
I guess I need a night sleep
Ok.
Some suggestions, for the first program:
config1 = ADC_FOSC_RC [B]&[/B] ADC_RIGHT_JUST[B] &[/B] ADC_[B]12[/B]_TAD ;
config2 = ADC_CH0[B] &[/B] ADC_INT_OFF[B] &[/B] ADC_REF_VDD_VSS ;
You want ADC_FOSC_RC AND ADC_RIGHT_JUST AND... don't you agree with me?
Raise the TAD a bit, just for experienting, in that case I changed to 12 machine cycles.
You chosed RIGHT JUSTIFY, what means that a 10 bit will be stored as 0x03FF, the high byte will store the 2 leftmost bits and the low byte will store the low byte.
So, if you want to overlay the lower byte by bringing the high byte down, you have to shift 8 times, not six. observe:
If I shift left 0x03FF 6 times and mask with 0x000F, I'm gonna get: 0x000F -> WRONG!
If I shift left 0x03FF 8 times and mask with 0x000F, I'm gonna get: 0x0003 -> RIGHT!
So:
// main loop
  while(1)
       [B] LEDS=(ADCResult>>8)&(0x0003)[/B]; // copy highes nybble ([B]8[/B] since this is a 10-bit ADC) [B]and mask with 0x0003, to throw out the garbage[/B]
[B]      DelayMs(1000); //Wait for 1 s so that you can see the LEDs[/B]
Why did I mask?
Lets imagine we have the 0x020F value at the ADCResult:
Think about it, when I RR the byte 8 times, this is going to happen, assuming that the [Carry] is 0:
Original:  [0]-0010.0000.1111
1st:       [1]-0001.0000.0111
2nd        [1]-1000.1000.0011
3rd        [1]-1100.0100.0001
4th        [1]-1110.0010.0000
5th        [0]-1111.0001.0000
6th        [0]-0111.1000.1000
7th        [0]-0011.1100.0100
[B]8th        [0]-0001.1110.0010[/B] -> 0x1E2, not 0x002!
So we mask with 0x0003:
0001.1110.0010
0000.0000.0011
0000.0000.0010 -> [B]0x002[/B]
Thanks for the help. It is very much appreciated. I have a different issue now, so I will post another thread.
Again thanks :)
Kansai
