AC signal input, what will be in the output of an opamp or a transistor
Otto_
Good day, everyone.
1) If an AC signal (for example, sine) is put into an opamp (which is supplied with DC), what kind of signal (AC, DC or pulsating DC) will be in the output?
2) What would be in the case of a single transistor (I suppose, it does not matter, BJT or FET, because anyway there is a p-n junction):
AC input --> pulsating DC output (like in the case of a diode as a half-wave rectifier); pulsating DC input --> pulsating DC output?
Thank You in advance
Solution
X1 is sine in, amplified linear, so output is amplified sine.
X2 is pulse, operated linear, so output is amplified pulse.
X3 is sine, overdriving circuit so output starts clipping, it cannot go above or below its
power rail pins.
Gain in all 3 circuits is 11.
But frequency matters, OpAmps have finite frequency response.
They also have slew rate limitations for large signals, slew rate refers to internal
current source limitations when charging internal compensation capacitor. So
for large signals, like ~1 V or more, and fast inputs like pulses, square waves,
one observes rise and fall time at output limited by slew rate.
Many other considerations, fascinating component...
In both cases it all depends on how the device, op-amp or single transistor, is biased and the configuration of the surrounding circuit.
Your question is far too vague to give a specific answer.
You should get an amplified equal AC waveform as the inputted if the circuit is properly tailored to amplify, or railed or peaked or differential or distorted or integrated if the circuit is tailored for that.
Good day, everyone.
Hello there,
In general, op amps are usually set up to amplify AC signals and maintain the integrity of the waveform. However, there are various conditions that can prevent that. If it's say an audio amplifier, it will most likely put out an AC signal that has the same shape as the input signal.
Transistors, on the other hand, are very nonlinear and so require a carefully designed circuit to be able to reproduce an AC signal. A transistor alone will not work at all, at least a few resistors would be required.
There is a lot of thought that goes into designing a transistor amplifier like an audio amplifier. The op amp amplifiers are easier to understand. If you are interested in both types of circuits, you can ask about each type separately and you should get some good answers.
power rail pins.
Many other considerations, fascinating component, probably more books and
papers on this component than any other.
Excellent reading, attached.
  • Intuitive IC OP amps_ from basics to useful applications -- Frederiksen T.M. -- 1984 -- CMC Pu...pdf
  • sboa092b (2).pdf
  • OPERAT~1.PDF
Solution
