Mosaic
Hi all:
I am going to have to run a 110VAC 0.21A Fan (brush less 120 mm), measured at 0.23A @120VAC.
Resistance is 158 Ω and XL = 440mH @ 120hz.
https://www.amazon.com/110Vac-Muffin-Cooling-Fan-120mm/dp/B00MNTEX0E
on a 220VAC supply.
Reactance calcs show a 5uF run cap to be 530 Ω reactance @ 60Hz which *should* be close to the fan's impedance (120/0.23 = 522Ω) but...when adding it in series the FAN speeds UP and draws 0.31A on 120VAC. The RMS voltage across the fan jumps to 142VAC, across the cap is 153VAC. So the phase shift/resonance is causing a lot more voltage to manifest across the load, which will probably wear it out before its time..
Placing two 5uF caps in series (2.5uF) now passes 0.15A into the fan at 120VAC. This drops about 76 VAC across each 5uF cap and 85VAC on the Fan
3 x 5uFs in series ( 1.66 uF) drops the 120VAC to 63VAC across the FAN and 48VAC across each cap.....which looks about right for use at 220/230 VAC.
I guess I can try for a 1.5uF/450VAC run cap to do the job, as it sees 144VAC manifest across it with 120VAC supply, I est. about 265VAC with a 220VAC supply.
Any thoughts on this?
on a 220VAC supply.
