I have made some headway. I was welding today with great success....but in a 2 steps forward, one back kind of way.
Changes to the circuit include increasing the value of R5 from 22 to 300 ohms. In the lincoln manual for the sp100, this resistor is 150 ohm so I figured with twice the supply voltage, this needs to increase. The engineer from IXYS felt that the problem with blowing the SCR's the way I was (going to a short vs an open) was a result of the gate trigger current too high but admitted it was a hard value to calculate. Even at 120 ohms, I blew scrs but at 1K, the circuit did not work.
He felt the timing circuit was ok but the trigger circuit was the issue. Normally, these scrs open on a fail and I was consistently getting a short.
I also changed C3 to a .012 capacitor which limits my delay to well under 8.3 mSecs, ensuring I do not trigger past the zero point, into the next cycle. I am not sure how close to the next zero point I can delay my on time but with practice, I will be able to set the welder for the values I need.
I have also installed MOV's across the SCRs and one from each line side to ground (earth)
I also upped the size of the SCR module. (tcmtech, you will be happy to finally hear...
) Again, the engineer felt like I had lots of "headroom" with the other one but the cost difference was not much more for the added security.
So, welding went well....given my ability levels. Control was good.
The new problem is blowing the main breaker (feeding the garage) or sometimes the welder breaker. These breakers can easily handle the welding current it self. I have welded at much higher currents before so I believe this new problem is to do with the high frequency box. I think I need to install a filter or filters on the line. I am guessing MOV's either in the panel or in the welder? These units were built to work together (welder and hi frequency box) and the high frequency box is meant to do exactly what I am doing with it but today, I turned it on after the welder was running and the breaker blew immediately. I reset the breaker and proceeded to weld for about 10 minutes. Sometimes the breaker goes when I am not welding so I am pretty sure it is something to do with the hi freq. Any suggestions?
Picture of installation is attached for those interested in the hardware end.
Thanks all.
Shawn
