Exo
Active Member
John Sorensen said:If you don't know what those "things" orbiting around atoms are, you might be at the wrong forum.
Lol, that one has to hurt! :lol:
zachtheterrible said:i woke up @ 3 in the morn last nite and couldn’t sleep, then I got thinking about perpetual motion (which did not help). Ive com to the conclusion that it IS possible. Think about a satellite orbiting the earth, itll never stop. And think about atoms, with those little things (I forgot wut they are called) orbiting around them . . .
Another thing I thout about was this: say you have an engine. It would need to be started somehow of course, but wut if as the engine is running, ALL of the heat that it produces, is converted back into energy and used to power the engine. Well, that’s my take on the matter
:lol:
lets say you get your satellite orbiting like you suggest. Lets also say that by some miraculous engineering efforts, it loses zero energy while orbiting. Not 1E-100 joules, ZERO. ok thats nice. But its useless. To get it to do any useful work an exchange of energy (conversion) will have to take place and that will have loses.
I think one key point of all hypothetical perpetual motion machines is they assume an energy conversion can take place with zero loss
If you are referring to energy cannot be created nor destroyed (conservation of energy) then as far as physics knows that is true. But it is also true that the second law of thermodynamics will guarantee that we will eventually never be able to recover the energy in a useful form.
thats wut i was going on, like my example with the engine if ALL the heat were able to be converted back to energy . . . ya gotta admit though, they'd be incredibly efficient.
As to electrons they don't actually orbit. They just have a probability of being in various places in that orbit. If I remember quantum mechaics correctly they don't really even need to move like an orbiting satalite - they just sort of exist at all points in the orbit untill you measure where they are. Once you measure them they chose a location. Quantum mechanics is really weird.
https://science.howstuffworks.com/fuel-cell5.htmGasoline-Powered Car
The efficiency of a gasoline-powered car is surprisingly low. All of the heat that comes out as exhaust or goes into the radiator is wasted energy. The engine also uses a lot of energy turning the various pumps, fans and generators that keep it going. So the overall efficiency of an automotive gas engine is about 20 percent. That is, only about 20 percent of the thermal-energy content of the gasoline is converted into mechanical work.
100% efficient to be exact Wink The theoretical maximum efficiency of a standard internal combustion engine is only something like 70% (our automotive experts can correct me on this one). There always seems to be (or rather there always is) something that steals a little energy making your system less than 100% efficeint.
bmcculla said:As to electrons they don't actually orbit. They just have a probability of being in various places in that orbit. If I remember quantum mechaics correctly they don't really even need to move like an orbiting satalite - they just sort of exist at all points in the orbit untill you measure where they are. Once you measure them they chose a location. Quantum mechanics is really weird.
Nigel Goodwin said:chemelec said:Nigel, You right about the motor. But Generating the Volume of Hydrogen to run a motor in a care at Reasonable speeds is quite a feat.
According to documented results, Stanley Meyers did it, Very Cost Effective. It not only ran the car, it generated the power to keep it going indefinately. It claims to run on Just water, Appearently this is quite well documentated.
Sorry, but I don't believe it! (as I suspect you don't?) - it's yet another 'perpetual motion machine'. As it's supposedly patented, all the details are freely available - yet it doesn't appear that anyone else can dulicate it!.
Looks to me like yet another scam!.
tansis said:We all have our doubts, and yet water as a fuel source is not as far fetched as it would seem. Controlled nuclear fusion creeps ever closer to becoming a reality...
tansis said:The same principle applies in both cases, more energy is released
than effort put in.
Water is one of this planets most odd chemical compounds,
in theory it should be a gas! Comercial / conventional direct current electrolysis requires huge amouts of power, yet water splits quite easily
under the action of certain forms/wavelengths of radiation.
Numerous patents can be found for similiar systems, each with a different
idea about voltages / freaquency / duty cycle
yields some interesting ideas, points ten (UV laser ) and thirteen (magnetic field) in particular. Even John Keely is reputed to have some success with puerly mechanical vibrations at around 620hz
tansis said:That leaves thermochemical hydrogen production - the use of chemical reactions that free hydrogen at lower temperatures than are required by pure thermolysis.
bryan1 said:this maynot be the right thread to say this but anyway,
I'm currently undertaking in a project on my farm to extract free power just using water and the sun. O'kay firstly I've got a pulser bore pump that will work off as little as 10 cfm of air pressure, the plan here is to use 2-80 watt solar panels using a maxi-maxiser circuit to work the 3/4 hp motor directly off the solar panels, and this will pump the water 300 metres at 150 metres elevation to a 20,000 gallon tank situated on top of my property. Then by using a 4" pipe and reducing the pipe over 500 metres downhill to a 1/2" pipe which will go through a 600 watt dc motor with a turbine which develops 16 amps@24volts to charge my deep cycle batteries. Not only will this give me plenty of battery storage but the excess power will be used to supply another pump to send the waste water back over the hill to start the process again.
I know this isn't perpetual motion but in my book it's an effiecient way to get free power using a few electronic circuits and about 4 kilometres of piping.
