In my last thread I asked about using op amps and low-pass filters to produce subsonic noise from a noise generator. Now I'm thinking about a different way to attack this problem.
Maybe it's time to go into the digital domain. My thought is this: use my same simple noise source (reverse-biased transistor junction), but immediately digitize the noise, probably with a simple squaring circuit (infinite-gain op amp stage).
Then, what if I just "stretch" the signal, by simply copying it over a longer time base? The diagram below should explain this:
First question is how to do this? Obviously, this would most easily be done by a microprocessor in software. This would allow one to easily change the "stretch factor" and thus the frequency spectrum. I know how to do that. I'm curious about doing this in hardware, though: can you think of a simple, elegant way to do this with a few gates? I can't at the moment, but haven't really thought it out (which I will do).
Of course, this will result in a fairly degraded form of the noise signal, since all amplitude information is lost. (It would at least preserve the randomness of the zero crossing spacings.) It's a quick-and-dirty, brute-force way of getting a usable LF signal. Much better would be to use an A/D converter (or does anyone have any other ideas how this could be done to preserve at least some of the original waveform?).
As always, thanks in advance.
